Results 1 to 5 of 5
Thread: vl has stuffed up again
    VL Berlina soon to be turbo'd
    Mar 2005
    Whyalla ..
    Angry vl has stuffed up again
    hi there i have resently had some one look at my car and fixed some of the problems it was running fine after he tuned it until the other day i was driveing the car and it started to surge i was sitting on 60kms and it sounded like a bucket of cr** now when the car is ideling it misses badly all spark plugs are fireing fine but it misses that bad now i can barly get over 70km and its so slugish it sounds like it is going to die i have never heard my car sound this bad what could i do to check the problems ? i know a littel bit about the motor but bugger all any help i would apreacite thanks
    My Car Pwns's Avatar
    My Car Pwns is offline 16 Mths Suspended Lisence
    Fully Sick Push Bike Uleh!
    Jul 2005
    have u checked ur fuel lines arent corrupted? also how much spark are you getting? did u alter the afm at all? i say take it back to the guy that fixed it..
    I wonder what those scales on the top right side of my posts do...
    Mar 2005
    Whyalla ..
    Angry MOTOR still stuffed
    hi there yes the afm did get adjusted i would have taken it back to the person who fixed it but he has gone back to s.a every plug is sparking and sparking good lots of volts comeing off the leads some days it runs fine the other days it runs like it wants to blow up ? i am going to put my mates airflow meater on there to c if it is that but i think it could be something else
    how could i try to find the probs what could be causeing the plugs to fowl up in less than 30 min and miss like its running on 3 cylnders i can barly get over 70km cause it surges like i have never seen before thanks for the tips
    i have a new motor lined up for it but i want this one running better so i can paddybash this motor untill it gives way unless i sell it first
    if anyone wants to bye this motor make an offer
    Konker Guest
    carb clean/. look down the carb and see if its all grotty. if so srpey carb clean or something down it. then get it adjusted as it sounds like a dodgey.
    Dellboy999 Guest
    Have you tried pulling codes from the computer, it may be a sensor going faulty and confusing the ECU.
  1. AFM - is it stuffed
    By Ross S in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-03-2007, 09:09 PM
  2. help key is stuffed
    By ace_bowler2000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-03-2007, 05:20 PM
  3. Need re gas or stuffed A/C?
    By bodgybro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-01-2006, 08:16 PM
  4. Stuffed Again!!!
    By My Car Pwns in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-11-2005, 08:57 AM
  5. Stuffed LSD?
    By GrpA Calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-08-2005, 02:43 PM
