Results 1 to 10 of 10
Thread: seized ball joints???
    vl
    Oct 2010
    upper hunter
    Default seized ball joints???
    g'day guys, tried everything to get these f@#$%&! ball joints out, anyone know why they wont come out???
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    vl
    Oct 2010
    upper hunter
    out of the stub axle mate, i pressume thats what your refering to as the knuckle???
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    thats because ball joints are a tapered fit usually 7 or 10 degrees this is so they dont come out what you need is a tool called a ball joint seperator and a big ####ing hammer
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    vr berlina
    Aug 2010
    australia
    hit the arm down with a hammer and the tapper should pop out
    if you canot get these out how are you going to change the ball joints you will require a press
    it would be cheaper to replace the whole arms as you probaly need new bushes to you can get the arms for about 140 each new bushes and ball joints and they just blot straight in and are made of 5mm plate not 4
    vr berlina
    Aug 2010
    australia
    i only ever use a balljoint seperator on say the bmw inner ball joint but one of the guys at work broke it so i just hit them in a certain spot and they pop out
    if you get a stuborn one get a mate with a crow bar to lever down on it and smack it then
    most tapers you hit the knuckle around the tapper but with vb-vp you need to hit the arm down with the lower inner bolt in
    try and hit as close to the joint as posible
    vl
    Oct 2010
    upper hunter
    lol, dudes i tried that! used ball joint sepporator, then got a pulley puller and put a heaps of pressure on it and used the balljoint sepperator, then i thought i'd use a bigger hammer and used an 8 pound sledgy, then i tried the crowbar trick with a sledgy
    most tapers you hit the knuckle around the tapper but with vb-vp you need to hit the arm down with the lower inner bolt in try and hit as close to the joint as posible
    what do you mean by that mate??
    also, im replacing the tie rod ends, ball joints, all the the bushes.
    vr berlina
    Aug 2010
    australia
    i mean on the older commos you dont hit the knuckle you hit the arm
    all i can say is what i get told at work try harder
    vl
    Oct 2010
    upper hunter
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    if theyre that stubborn hitting the lower control arm down is a good way but make sure the car is secure. it'll also have to be still bolted into the k frame. I prefer a ball joint seperator less chance of damaging anything bar the ball joint i never had a problem using one but some people have had experiences like you
  1. vs ball joints
    By sik888 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2008, 04:13 PM
  2. ball joints
    By birdy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2006, 01:51 PM
  3. ball joints
    By 90VN55 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-06-2006, 11:27 PM
  4. Ball Joints
    By holster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-06-2006, 08:24 PM
  5. New ball joints
    By AL-X in forum Holden Commodore How-To's
    Last Post: 27-11-2005, 07:27 AM
