Results 1 to 9 of 9
Thread: vl transmission fluid
    VL Commodore
    Oct 2010
    Default vl transmission fluid
    Hi all. Im new to the forum and have my first contribution (in this case question). I checked my VL transmission fliud and its too high. How do I reduce the level?
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    How much over is it. How are you checking it? Meaning, do you have trans fluid at operating temp and do you have car running and in park/neutral on flat ground?
    VL Commodore
    Oct 2010
    Thanks for your offer to help. The fluid reads about twice as high as the full mark. ie if it was half the level it would be on the full mark. the car is on level ground and was last driven about 40mins ago. the oil is not hot but luke warm
    VL Commodore
    Oct 2010
    '87 VL Calais with L67
    Aug 2007
    bloke, you need to have the car running and in p or n when you check it. the level goes down when the oil pump in the trans fills all the gallerys and the valvebody.
    try checking it again in the park or neutral position and see how you go.
    This is good site to watch.I found it informative as I have been researching a lot lately on such matters such as you talk about.
    HoldenOnn's Avatar
    May 2009
    Busselton, WA
    Also, another peice of advice I can give you is to go and buy yourself a repair & service manual such as Gregory's/Haynes from Repco, Supercheap, Autobarn etc. I have owned and raced VL's for the last 15 years and I can't remember how many times that the service manual has come in handy for either a torque setting, or how much oil the sump takes, or how to check trans fluid etc etc.
    It has so much information that can save you money and time.
    vl berlina wagon 6cyl
    Jul 2005
    if the level is too high after being correctly checked, its easy to remove 1 of the fluid hoses to the trans cooler at the radiator and with engine idling, pump some out
    the auto trans sump has no drain plug
    many trans problems are caused by a too high fluid level, so be careful
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    when removing fluid as above has mentioned, remove the top trans hose from the radiator place it in a coke bottle or similar (so you can measure how much you have removed, judging from your dsescription I would suggest removing approx' 1ltr), it pumps out quiet quickly, and you should have someone start the car while you monitor how much comes out , then have them stop the engine. also you should have some degreaser and a hose ready for the clean up it can get a bit messy.
    Nobody wants to play with me
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Jatsvl u r always on the money... must be all the beers u neck keeping the gray matter active.
    Yeah as said man car running level ground and neutral. torque converter takes a bit, as well as valvebody
    check the color and smell of the fluid as well if its dark or it smells (burning) replace oil and filter
  1. How much transmission fluid?
    By deXtrous in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2010, 10:28 PM
  2. Will a car run without transmission fluid?
    Last Post: 07-07-2010, 03:08 AM
  3. how to top up transmission fluid
    By nielsonp in forum General
    Last Post: 03-02-2010, 09:13 PM
  4. transmission fluid
    By rob drag racer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-05-2009, 08:45 PM
  5. Transmission Fluid
    By MavVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2004, 10:07 PM
Tags for this Thread
