Results 1 to 7 of 7
Thread: Fuel Gauge not working VL
    VL Commodore
    Oct 2010
    Default Fuel Gauge not working VL
    Hi all AHs anyone had any problems with thier fuel gauge. It only works sometimes. Do you think that it has something to do with the connect with the fuel tank? If so what should I do...thanks
    VZ HSV Senator, VL calais RB25 turbo
    May 2010
    Norsey
    pretty common on vls. if its sticky needle try giving your dash a whack. if that doesn't work then it could be your level sending unit or faulty wiring. try checking all the connections and such before pulling things apart. could save you time. goodluck
    VL Commodore
    Oct 2010
    VLC86's Avatar
    VLC86 is offline ..stay N/A..
    VL Calais
    Dec 2009
    yeah mate. I have the same problem. Tapping the gauge always seems to work for me.
    World's slowest project
    Quote Originally Posted by hi_ryder View Post
    for entertainment purposes only, hi_ryder does not condone the murdering citizens on assumption of theft, or illegal firearms possession
    May 2010
    Norsey
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    yes same here tapping the gauge works for me too, so I would suggest the needle in the gauge is sticky.
    any ideas as to what lube to use for the gauge?.
    Nobody wants to play with me
    VT HBD LS1, VL calais project
    Nov 2009
    SE bris
    hey mate click on the link this will show u how to fix that fuel gauge...
    Vl Fuel Gauge Fix - calaisturbo.com.au
  1. VT Fuel Gauge not working
    By LittleMissVE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-04-2010, 07:23 PM
  2. temp gauge an fuel gauge not working
    By nathan_867 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2010, 10:55 PM
  3. fuel gauge not working (VR)
    By orbisfactor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2006, 07:59 PM
  4. Fuel Gauge not working
    By scojohara in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-11-2005, 08:15 PM
  5. Fuel gauge not working
    By 5Lvrss in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-04-2005, 11:21 PM
Tags for this Thread
