Results 1 to 14 of 14
Thread: VL Not Starting
    Scottie666's Avatar
    Scottie666 is offline Scottie
    Vt Acclaim, 1988 Vl Comm,2007 VE BERLINA
    Apr 2009
    Default VL Not Starting
    Hey guys,
    my bro in law has an 1988 vl which i sold him, it was running before i gave it to him but it ran outta fuel. we have put fuel in it and it won't start take the fuel line off and turn the ignition and it slowly trickles fuel out of the fuel line, should it actually piss out?
    any help would be great
    cheers
    Scottie
    vy2 clubsport
    Feb 2008
    adelaide
    Scottie666's Avatar
    Apr 2009
    so if it's not pissing out what would be the cause in fuel pressure drop?
    VZ HSV Senator, VL calais RB25 turbo
    May 2010
    Norsey
    blocked filter?? when it ran out of fuel it couldve sucked in some contaminent from the bottom of the tank. and it could also possibly be in your fuel pump or the lines. try change the filter and while the hose is off see how much comes out there. if it pisses out its either filter or lines so you should be able to work from that. hope it helps
    Scottie666's Avatar
    Apr 2009
    Scottie666's Avatar
    Apr 2009
    ok did the fuel filter and lines and also swapped the fuel rails over with another car,
    still nothing, shit loads of fuel pissing outta the fuel lines now ,
    even if there is spark the crank angle sensor could still be rooted right?
    Scottie666's Avatar
    Apr 2009
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    well yeah this can happen even though the CAS is responsible for spark..could still be Farked
    So u got Fuel
    Compression and spark
    Should b it theoretically..
    Try another for Piece of mind man,.
    Hows injectors? check relays and fuses etc
    89 vn berlina wagon,94 vr clubby mock up
    Mar 2010
    bendigo
    if u run them dry the fuel pumps do burn out and need replacing i found this out the hard way
    May 2010
    Norsey
    but hes getting plenty of fuel so it cant be the problem.. although i have also done this before
    Scottie666's Avatar
    Apr 2009
    ok we fixed the problem, we kicked ourselves so hard, even though we had spark and seemed like heaps, the coil was actually farked, we replaced it with another and the bloody thing won't stop running hahahahaha
    May 2010
    Norsey
    vl calais
    Oct 2010
    vict
    hey my vl wont start it just winds ova just wont start wat would that be everythin was all good with it till i change my plugs and leads
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    have u got the leads right from the dizzy to cylinders?? looking at motor it is inline front = 1 - 6(at firewall) numbers are marked on the dizzy cup.
    Easy mistake to make.
  1. VS V6 not starting
    By Andrew426 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2009, 12:18 PM
  2. vs not starting
    By james90vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2009, 11:26 AM
  3. Vn Not Starting.
    By K1ND3R in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2009, 09:18 PM
  4. vt ss not starting
    By djlingard in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-01-2007, 05:06 PM
  5. Car not starting
    By [JUDGE] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2006, 03:30 AM
