Results 1 to 19 of 19
Thread: How big can I go?
    WK statesman 5.7, VS exec TURBO
    Sep 2005
    mornigton penisula VIC
    Default How big can I go?
    Hi guys, I'm building a vl turbo wagon and I'm looking at different sized intercoolers. How big can I go without cutting to much away. I'm looking at a 600x300x75. I want it to be massive but I want it to still fit behind the bar. Thanks for any advice.
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    vy2 clubsport
    Feb 2008
    adelaide
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    depends how long you want the cooler pipes or if you want to cut holes.you can fit a 300x600x76 with pipes at the bottom and run long pipework or can run a 300x450/500x76 and fit it with outlets at the top and run short pipework but need to do 2 holes to get pipes into engine bay.cuts out lots of bends and length out the pipework both will keep it plenty cool
    VT SS S2 A4
    Aug 2005
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Sep 2005
    well i recon i mite go for the 600x300x76.
    are those ebay ones any good? or r they dodgy like everything els on ebay?
    i just hate doing things to find out there was a better way to do it.
    vl commodore and vz ss
    Jun 2010
    dodgy dont wast your time or money get a reputable brand from the start do it once do it properly
    Sep 2005
    Fair enough. What brands are good ones to look at? I don't really know much about coolers.
    VT SS S2 A4
    Aug 2005
    Quote Originally Posted by base308 View Post
    VL GOD ran a 9 sec quarter with a cheap ebay cooler.
    Jun 2010
    в∞ѕтεכ √&
    Jul 2008
    NZ
    i put $150 cheapo coolers in every build never had a problem yet no leaks keeps intake temps really low like they should about to see how much flow im looseing through the cooler but i wouldnt expect it to be that bad on the big coolers
    VT SS S2 A4
    Aug 2005
    tell that to my mate who cracked 2 pistons in his turbo escort
    maybe he needed a better tuner
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    yeah and its an escort LOL..... and a ford :P
    I have an ebay jobby,$200 not a worry , keeps it cool, motor not fried,looks the part, neat tig welded,
    Do it once, do it intelligently more so
    not stupid boost levels and a bodge tune.
    2 types too man Bar and Plate cooler or Tube and Fin cooler, each to there own, but expensive coolers vs cheap coolers basically u r paying for the brand. minimal pressure drops and restrictions between the 2.
    GKteck make a good Vl No hole cooler kit they are based in melbourne all piping and cooler for about $600.
    I shopped around for a bit and found the ebay cooler $200 and piping second hand for $150 all joiners and clamps..(ebay as well)
    good luck man
  15. #15
    Sep 2005
    Thanks for all ur input guys. I'm going to be runing about 20-25 psi on the track. So I want it too hold together. It's going to be more of a strip car then a street car.
  16. #16
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    make sure u dont skimp on the hose clamps get the "T" bolt ones not the (tridon/repco phillip screw type ones) and silicone joiners <---- Not cheap dem der joiners.
  17. #17
    Sep 2005
    thanks. ill keep that in minnd. i guess i dont want cooler pipes blowing off
  18. #18
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    yeah i have seen on you tube in a dyno shootout some bloke was boosting up some 30 odd PSI and cooler pipes flew out his engine bay about 10 feet above the car.. preety funny. have a search
  19. #19
    в∞ѕтεכ √&
    Jul 2008
    NZ
    T-bar clamps FTW them suckers will crush alloy and are only $3.50 each about the same price as a 3" tridon clamp
