Results 1 to 8 of 8
Thread: difference in rb30 heads?
    vl 5 speed duel fuel
    Sep 2010
    canowindra nsw
    Default difference in rb30 heads?
    just wondering if anyone knows what the difference in the rb30 head is? (as in number wise)
    my old head has 672 then 1 under that and the new head has 672 then 3 under that and then L under the 3? does anybody know what this means?
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    probably just stamped at factory to determine something dont really know...
    Turbo head is same as NA head though only the cam is different with the lobes are slightly different to allow more exhaust to turbo and intake etc. 5degrees or something.
    Sep 2010
    canowindra nsw
    ok sweet. do you know if the lifters have to go in a certain way as when i was changing over the cam and rockers a couple of the lifters cameout and i just put them back in there where i thought they might go. they have a little hole in the side of them obviously to let the oil threw but no idea?
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    anyway as long as u marry up the lifter and the cam lobe it came from dont mix and match , oil hole anyway it can go. clean them and soak them in fresh oil b4 u put them back in...
    May wanna hear from other members as well b4 u continue. or have a look around google.
    de_overfiend's Avatar
    de_overfiend is offline Beef is Good
    VS Calias
    Aug 2008
    Tweed Heads
    1 means series 1, 3 means series 3.
    not much difference except for porting. dunno what the L means.
    vy2 clubsport
    Feb 2008
    adelaide
    VL CALAIS TURBO
    Nov 2010
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    yes it is a DIY job depends on you General Knowledge.
    But easily done
  1. Nissan RB30 V Holden RB30???
    By neatvl86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-01-2011, 01:08 AM
  2. Modifying standard RB30 to RB30 block / RB25 head + turbo... HELP!
    By 86VLred in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-09-2010, 12:07 AM
  3. skyline r31 rb30 coil on vl rb30 motor
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-04-2009, 10:30 PM
  4. difference in nissan heads
    By bangers in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-01-2007, 07:34 PM
  5. Rb30 Heads
    By vl 88 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-04-2004, 09:52 AM
