hey i need to get my motor up and on the stand to strip it and i need to know what size bolts i need to bolt it up to the stand. its one of thoses red 450 kg stands from supercheap. also need to know how many and what size bolts are needed to bolt the motor up to an auto gearbox. from memory they were different lengths..
From memory 10mmx1.5 at least 125mm long buy some good high tensile washers aswell as the bolts will go through engine stand. I had 4 for mine and it was fine if you buy the packs from repco or the like they come with nuts aswell.
Originally Posted by Smidy
Measure them yourself?
If you can't do that, I don't know why you're putting it on an engine stand.
thanks mate i will go and buy some.
and vt 565.. i dont know if u can tell but i was after some advice not useless critisism. i cant measure bolts that i do not have? or anything for that matter as i do not have a tape measure on hand. obviously u must for some reason????. and ive never used an engine stand before. why dont u trawl through the forums and find some other person to have some pathetic anonymous crack at. some people..
