Results 1 to 6 of 6
Thread: Rb30 block rb25 head with supercharger need help
    VL Calais
    Dec 2009
    Default Rb30 block rb25 head with supercharger need help
    Hi all a little while ago i got this crazy idea to build a hybrid motor but change it up a bit with a supercharger can anyone help me i need to no what superchargers will fit and what else i am missing from my build mind you this is going into a VL so it will all need to fit under the hood...
    Heres what i have so far:-
    RB30 Block - Blue Printed and balanced
    RB25 Head - Non VVT (i think still in the mail waiting for it to arrive seller didnt no anything bout it will update when recieved)
    RB25 forged - Crank, pistons & rods
    Haltech 2000pro Series with racepac display
    JDM Turbo manifold (hopefully will work with suppercharger new to forced induction correct me if im wrong)
    1000cc injectors and fuel rail to suit with fuel regulator
    _______
    Am i missing anything I no i need a new fuel pump and lines any recomendations ?, and do i need to do any work to the head if its non VVT?... does anyone no what else i need to do this build any help would be apprieated
    de_overfiend's Avatar
    de_overfiend is offline Beef is Good
    VS Calias
    Aug 2008
    Tweed Heads
    vy2 clubsport
    Feb 2008
    adelaide
    fuel lines should be ok i reckon.bosch 044.good luck at least your trying new things
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    VL Calais
    Dec 2009
    Hense the Haltech 2000pro series with racepac the ecu alone is $3200 and then add tunning plus water and oil sensors, wiring harness, im looking all up just on the ecu side $4200 this Sh*t is expensive, wanted to go a motec but then deerer again and harder to find someone to tune them,
    ______
    VL Calais
    Dec 2009
    I have just decided i need a supercharger with butterfly flaps for inlet you no the ones that you see on massive v8s recon it would look sick even if they were off to the passenger side of the bonnet anyone no of a supercharger that i could mount to do that with ???
  1. Modifying standard RB30 to RB30 block / RB25 head + turbo... HELP!
    By 86VLred in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-09-2010, 12:07 AM
  2. Rb20, Rb25, Rb26, Rb30..... ?
    By Marco-EFIVL in forum Straight 6 Development And Modification
    Last Post: 30-12-2009, 12:40 PM
  3. [VIC] WTB: rb25 or 26 head
    By Nackerz in forum Swap / Wanted to Buy / Trade
    Last Post: 13-11-2009, 02:10 PM
  4. RB25 Head On A RB30 Block, How Hard?
    By lkrrepz in forum General Discussion
    Last Post: 21-08-2009, 12:00 PM
  5. rb25 head on rb30
    By starfire vc in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-03-2008, 09:57 AM
Tags for this Thread
