So my fuse block has melted on fuse 1 ,2 and 5. I think ive fixed the problems the previous owner did and installed relays in the headlight system. Now because me and my car and me are in thailand its hard to get a replacement fuse block.
My question is - I there anything connecting the fuses sideways along the fuse block- 1st to 2nd to 3rd fuse etc?
I wanna cut the fuse block between the 1st and 2nd fuse to make it easier to fit the new inline fuse.
cheers Andy
cant you get some of thoes spade fuses some wire and wire cutters to make temp repairs? (not a vl guy soo not shure)
Thats the problem. The spade fuse has melted into the fuse block. Its a mess. I wanna separate the fuse block so i can easy get under it and cut the correct wires to splice in a new inline fuse.........but i dont want to f#ck it more....
would a whole new block from the wrecker be easier?
hes in thiland atm i dont think they would have another vl floating about
umm if there are wreckes were you are check if the have a old skyline i think they might have what you want if not smash it apart and rewire it with new connections and spades and tape em up outta the way not too much tho or its a fire haz
Cool so i didnt think there is a prob separating the 1st fuse part from the rest of the block right?
Can anyone confirm this?
i cant imagin it would but i cant be sure can ya send pics and also say what each one is for(again im not familure with vls) oh and do ya have some cool pics of the vl in thiland?? dont think ive ever herd of one outside of aus
will try and get pics of the fuse up later. ATM the car doesnt look too good. Ready for paint soon. The VL was sold in thailand for only a short time. Ive seen one or 2 camiras kicking around and a few VN's but this is the only VL calais ive seen or can find info on. Its been passed from aussie to aussie to aussie here LOL
Cool thanks for the help guys. Also had to try some thing quite interesting to repair the headlights. So i will post it up when its finished
yeah man 2 screws to lift it up cut the wires to the appropriate fuses and rewire them with your own inline fuse.. its a common thing on the vl. easy and a must... dont bypass the fuses it will be a bad move bloke.
goodluck
yeah cut and re solder onto another spade fuse and best thing is to check out what's causing the melted fuse (high beams, etc)
cheers tom
