Results 1 to 4 of 4
Thread: Help Needed
    crazy for vl Guest
    Arrow Help Needed
    hey guys
    couple months ago i replacede new engine on my vl and that was leaking oil
    and today i started the engine and after couple minutes engine started to shake and does not idle proparly .i checked the oil and thats was ok.
    i know engine needs new injectors but i dont think thats from injectors..help needed........
    THANKS
    Pistol Guest
    the prob could be form the injectors but you wont know until you get them fixed so id do that before you look at anything else. the only other thing i can think of is the timing. if the engines cold it may not notice it as much becuase the fuel mix is richer for the cold start but when it warms up it becomes a problem.. i had the same thing on a toyota and thats what it was.
    My Car Pwns's Avatar
    My Car Pwns is offline 16 Mths Suspended Lisence
    Fully Sick Push Bike Uleh!
    Jul 2005
    check the spark plugs are in the right firing order., this could very well be the problem.. the order is on the lid of the distributor cap.. i had this problem.. put them in the right order and ran like a dream..
    I wonder what those scales on the top right side of my posts do...
    danny_sway is offline danny_sway
    Vl commodore SL executive
    Sep 2005
    i had that problem in mine rescently. at night go out start it up and pop the hood just enough to seee under. in pitch black if your problem is the same as mine u will see little blue sparks jumping where cables are faulty cuaisng it to miss fire. if so just go buy a set of new leads for $50. if it aint this check the distributor cap and spark plubs
    just a thought
  1. Help needed Please
    By B J in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-09-2007, 07:53 PM
  2. 308 or 253 Needed
    By vasrox in forum Swap / Wanted to Buy / Trade
    Last Post: 27-03-2007, 07:06 PM
  3. help needed with fan
    By Spury in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-12-2005, 02:25 PM
