Results 1 to 8 of 8
Thread: Removal of VL Doors
    vl berlina
    Sep 2010
    in a house
    Default Removal of VL Doors
    hi this may have been posted before but how do you remove the doors on a vl commodore someone told me you have to buy a special tool to do it but that costs $89 has anyone made there own door removal tool or have an easier way of removing the doors thanks for any help you can give me
    5.0 VL Wagon
    Jun 2009
    Yep definitely need the tool from my experience...I had taken about 8 doors off before no other easy way i found unfort...
    VX 'S' S1
    Apr 2005
    South East,Victoria
    You can use a drill bit or something similar and use it as drift to knock it out . the pins are a couple of buck each. Make sure you wear safety glasses .
    executive vt 5.0lt
    Feb 2005
    west suburbs
    i made up a tool with a piece of threaded rod from bunnings, i put on some small nuts then filed them so thay fitted into the hinge, the rod was about 18in long, then put on the head of a knock hammer with a couple of large washers then used it like a slide hammer worked a treat make sure you use plenty of wd40 to lossen the the pins the pins only come ouy one way i think the top one is down and the bottom pin up
    vl berlina wagon 6cyl
    Jul 2005
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    what a pain in the arse job this is, the right tools make it easier!
    and as gungazza has said, TOP PIN DOWN - BOTTOM PIN UP get it wrong and you will be sorry!
    Nobody wants to play with me
    VL Series 200 , 85 VK Berlina, VL Executive Wagon
    Apr 2010
    I can not beleive how hard this job is.. im trying at the moment and have only managed to get 2 doors off. using a hammer and flathead screwdriver and a centre punch thing. the bottom pins are near impossible! anyone know where to buy new pins from?
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Holden sell the pins .Give them a good spray with some WD 40 and let them soak overnight . The bottom pins will come out easier if you knock them up from the under the hinge then grab it with a pair of multi grips then hit them with a hammer. After being in the hinge for 20 odd years they tend to get rusted in .Its best to use something that is just a tad smaller that the hole in the hinge but not too small as the hinge pin is made of spring steel with a slot cut down the entire length and if you use something too small it spreads the pin open and it get jammed.
  1. FS [VIC]: VS stato rear doors w/ door trims, VS 'S' Ute complete doors and VS Seats
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 28-08-2008, 07:04 PM
  2. HOW TO fix small dents in doors incl. trim removal w. pics (VN-VS)
    By levymetal in forum Holden Commodore How-To's
    Last Post: 25-06-2008, 01:11 PM
  3. car doors removal?
    By creamy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-05-2008, 10:57 AM
  4. Are VY ute doors the same as standard VY doors??
    By sokeefe1984 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-04-2008, 04:24 PM
  5. How To: Doors and centre console removal
    By premmy186 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-02-2006, 12:46 PM
