Results 1 to 4 of 4
Thread: Another question about the Timing on a VL
    VLC86's Avatar
    VLC86 is offline ..stay N/A..
    VL Calais
    Dec 2009
    Default Another question about the Timing on a VL
    SO I need to set the timing on my VL
    And what Im after is a detailed description with what I need to do in a simple terms. I have no idea how to do it and as usual the max ellery manual proves to be useless. I want to get this done tomorrow if I can so I dont want to go buy another workshop manual.
    Preferably no long/hard to understand words as im sleep deprived at the moment.
    cheers
    World's slowest project
    Quote Originally Posted by hi_ryder View Post
    for entertainment purposes only, hi_ryder does not condone the murdering citizens on assumption of theft, or illegal firearms possession
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    VLC86's Avatar
    VL Calais
    Dec 2009
    heads back on. marker on the top pulley is facing directly upwards. Basically need to remove lower timing belt cover and then go from there. Belt has just been replaced.
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Here bloke. 53 Teeth marks on the belt(grooves). C pic Loosen the tensioner and move it aside. get it happening with the belt then push over tensioner and tighten. Turn over a few times and tighten tensioner again. Send me ur Email in PM and ill send u more detailed
  1. Timing question
    By Jordo2 in forum General
    Last Post: 17-08-2010, 04:35 AM
  2. VZ S Ute valve timing and exhaust question
    By johnn in forum V6 Development And Modification
    Last Post: 28-04-2010, 06:33 PM
  3. Advancing the cam timing question
    By Ross S in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-03-2007, 02:58 PM
  4. Vs V8 base ignition timing question
    By myvscalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2006, 07:30 PM
  5. Timing chain question
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2005, 06:14 PM
