Results 1 to 7 of 7
Thread: idle fine,drive like shit!!
    vl commy
    Nov 2010
    adelaide
    Default idle fine,drive like shit!!
    hi all a mate of mine has just brought a vl and it idles fine but when under acceleration it seems to be missing a beat or two and has no go!!!just wanting to see if anyone else would know what the problem might be!!i was thinking afm or maybe try to advance the timing!!
    VT SS S2 A4
    Aug 2005
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    vx s-pac
    Nov 2010
    victoria
    It could be the timing. This happened in my old vl and i borrowed a timing light from a mate and ajusted it the best i could and it made it run so much better.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    vy2 clubsport
    Feb 2008
    adelaide
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    Check your ignition leads at night & look for any sparks - easy for these to short out - also VL's are bad for EFI electrical connections - if the boots are broken you can buy new connections & boots - put some dielectric / silicone grease on all connections as this is the biggest problem with these - especially the one at the distributor as water will get in & damage the bearings. Then you get rust dust over the pickup & she had it - all over red rover... The grease works by promoting a connection - stopping corrosion - you can put it on anything & it should be part of your toolkit. Supercheap sells it in small sachets for putting on ignition leads & the like - Repco can sell you a larger tube but its not cheap - around $60 a tube. Works great in light sockets & anything electrical. Nowadays with computers - they are running very low voltages & any corrosion will cause you problems - this was the first thing we used to do with a VL when it came into my workshop & most times it would fix the problem. If you are tight for money you can seal up the connections without replacing the boots by taping them up with rubber self vulcanizing splicing tape - available from your household electrical suppliers (240v). They usually always have it. You stretch it & it heats up & vulcanizes itself & wont come off... Good luck
  1. 5ltr VR won't idle on gas, Fine on Unleaded
    By Uber_Flacky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2010, 11:04 AM
  2. VS SII rough idle on gas - fine on petrol
    By joyfam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-08-2009, 02:59 PM
  3. idle hunting in drive
    By scoota72 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2009, 07:54 PM
  4. Idle in Drive rough
    By hittmann81 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-04-2007, 06:30 AM
  5. bad idle in drive and reverse
    By VSIIBerlinaL67 in forum V6 Development And Modification
    Last Post: 25-08-2005, 12:13 AM
