Results 1 to 12 of 12
Thread: reverse lights
    vl executive 86
    Mar 2010
    Default reverse lights
    Hey I know this may have been covered ages ago but my reverse lights are not working.
    Have checked if there is power and yes there is have checked the selector on the gearbox and that is fine I was reading that i may have to wire a switch up myself to turn the lights on or repair the sockets for the light
    Am wanting to go for my rwc next week so any help will be very appreciated
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    well man if u r getting power to the lights sockets,, i would think u have a bad connection onto the globe contacts..
    I know if there is a bad earth here as well u will get the same effect.
    so spray some contact cleaner or Wd40/INOW in the plug and give the globe a good wiggle. check the earth (black wire on the side of the socket. has a spade connecter on it.)
    I had a problem here a few years back was a bad earth. even try and pull the contact pins up a bit as they may not be contacting the globe..
    Get a mate to sit in the car in reverse and try this method. As long as u trust him not to run over u.
    If u cannot get it to work still... go to a wreckers and grab some more from a VL or VK etc as the sockets are the same.
    Goodluck man
    Let us know
    vl executive 86
    Mar 2010
    Thanks will give that a go this weekend and try and find out what's going on thanks again for the quick reply
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    You can just have it in reverse and put it on reds and the reverse lights should come on. Mine's manual though idk about yours
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    vl executive 86
    Mar 2010
    hey do you mean accelorator on and then put in reverse?? cause even when i put in reverse and reverse up the lights still dont work as i said this weekend i will test everything out, have a mate that has had problems like this before hand so hopefully we can get that sorted. Thanks again, will let you know on how it goes.
    calais24/7's Avatar
    Jul 2009
    what we mean is that normally your reverse lights should come on when in reverse and your ignition on acc. So there is no need to start the car. Goodluck man.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    auto or manual?
    both operate differently.
    btw manual is the easy fix.
    Nobody wants to play with me
    vl executive 86
    Mar 2010
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    assuming, you have checked fuse #11
    also have someone stand behind the car and and slowly select all the gears, to see if the lights flash/or come on in another gear other than reverse.
    you said you have got power but is that in the reverse light socket? If so it is just a contact problem as mentioned above.
    otherwise, the reverse light switch is part of the neutral safety switch on an auto, therefore you will need to test that!
    here is some info.
    Attached Thumbnails Attached Thumbnails reverse lights-neutral-001.jpg   reverse lights-neutral1-001.jpg
    vl executive 86
    Mar 2010
    Hey guys thanks for the quick replies, got them working. The contacts for the earth were not touching and the contacts on the bottom were not touching as they have been pushed down too far. Got them done and going for rwc today. Thanks again guys
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Hey good work man.. knew it was nothing to drastic as u had power at the plug.
    good work
  1. Reverse lights not working on reverse
    By macca_223 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2010, 11:02 PM
  2. vn Calais rear lights, rear indicator, reverse lights and fuel gauge stop working
    By rustyguy085 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-11-2009, 08:25 PM
  3. reverse lights
    By Rubber_Burnin_Gal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-06-2008, 11:03 AM
  4. VY Reverse Lights
    By hitman1979 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-02-2008, 06:36 PM
  5. Reverse Lights
    By ducatis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-01-2007, 10:07 PM
