Where do i find a stage 2 shift kit for my auto VL?
Auto transmission shop
seen a few go on ebay
DIY jobby
How hard is it to fit.
any good on a vl turbo with a n/a gearbox ?
Modifying a car is like a drug once you start you cannot stop
Holdens if your not in one your behind one
get a turbo box man. or source a Vl turbo 5 speed box (MX7) normal auto box will slowly fade. u can help it along with a trans cooleri know the vl has the one in the radiator as well. but go an aftermarket one. i havnt im using the stock one.
I have had my N/A box for the 12months this turbo setup has been on but im only running 6psi its starting to get tired though and i have not been nice to it LOL how can i
Installing a shift kit man basically u r drilling out a few holes a little larger and installing some higher tension compression springs in the valvebody.
me personally would not do it, untill i get another box. either built stronger or go the MX7.
Yer i plan on going 5 speed once i pop the auto
With a 5 speed ive been told that a heavy duty twin plate would help it heaps.
Alright cheers for the help il sus out the MX7
