Results 1 to 8 of 8
Thread: Thermal fan alway on...
    VL RB30 Berlina
    Nov 2003
    Default Thermal fan alway on...
    hey all.....i noticed the other day that the thermal fan for the air con is on all the time, so i took out the relay and it stoped.....thinking it was just the relay, i put a new one in but as soon as i put it in, the fan came straight back on........if anyone has any ideas it would be great as i don't have much time to do these things anymore cause of work.....thanks!!!
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    how is your car temp running?
    Maybe it is a bit high and is relying on the booster fan to get more air through the radiator, not just for the aircon
    Just a thought :P
    VL RB30 Berlina
    Nov 2003
    i thought that cause the temp was higher than usual, but i disconnected it and it went back to the usual opepating temp.....
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    hmm could not tell u mate maybe the relay is stuck on when u turn the aircon off.
    causing the fan to stay on, but not the compressor relay for the aircon
    Best take it to an auto electrician, for investigation...
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    check and see if the air con is switching off. it should come on when you select the windscreen setting so make sure its not on that.(i dont mean feel for cold air, actually check and see if the pump is engaged) if the air con turns off and the fan still runs chances are itll be the temp sensor. find it, and pull the plug off it and see if anything else changes.
    VL RB30 Berlina
    Nov 2003
    the compressor is not on when i turn off the switch.......i'm pretty sure it is the temp sensor but i don't actually know which one it is!!!!!
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    failing everything else just unplug the fan til summer when your using the ac, then it doesnt matter if the fan is on all the time!
    BUT im the one that usualy says "its not meant to be doing that so it should be fixed" and from there im out cos i wouldnt have the same setup as your car to be able to help.
    VL RB30 Berlina
    Nov 2003
    thanks......i still looking but i did unplug the fan.......i agree with you with the ain't supposed to be doing that bit......that's why i trying to get some info!!!!i think that the sensor behind the engine temp sensor might have something to do with it but my gregories book doesn't say anything about it(or the air-con for that)
  1. Thermal fan cost?
    By Rangee in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-07-2006, 08:59 AM
  2. thermal fans
    By wbcaprice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-07-2005, 03:50 PM
