Page 1 of 2 12 LastLast
Results 1 to 25 of 41
Thread: Need help starting the car after head reco
    VLC86's Avatar
    VLC86 is offline ..stay N/A..
    VL Calais
    Dec 2009
    Default Need help starting the car after head reco
    Hey guys.
    As a couple of you might know, I recently got the head reconditioned on my calais.
    I took it off myself, and put it back together myself. I have folowed the instructions putting it all back together and it took me a while to do it. When I finally tried to start it, it wont turn over. I have checked and it is getting a spark and I can hear the fuel pump when I turn the car onto accessories. But it just wont start up.
    Im guessing its possibly anything really.
    But what can I check to eliminate possible causes. (fuel, ignition etc.)
    Car hasnt been started in about 2 months but I repeated everything I did to remove the head and now it wont start
    Any help would be greatly appreciated
    Thanks guys
    World's slowest project
    Quote Originally Posted by hi_ryder View Post
    for entertainment purposes only, hi_ryder does not condone the murdering citizens on assumption of theft, or illegal firearms possession
    VLC86's Avatar
    VL Calais
    Dec 2009
    New discovery is that I have a very weak spark coming from the 6th spark plug. Spark plugs are relatively new Bosch iridium ones.
    Not sure if this helps but I really need to work it out
    vy2 clubsport
    Feb 2008
    adelaide
    Iridium plugs are a waist. Having one week spark plug doesn't meen it won't run. Sounds like timings out 180 . How did you set up timing ?
    VLC86's Avatar
    VL Calais
    Dec 2009
    Quote Originally Posted by bow down View Post
    I realised that I should have gotten copper plugs afterwards.
    I think it could be possible the timing is out by 180 degrees. I followed the gregories manual. I rotated the top pulley 180 degrees before puting it all back together, so the mark on the top pulley was facing directly down. I have a feeling this might be the cause.
    How can I adjust the timing back?
    vy2 clubsport
    Feb 2008
    adelaide
    i dunno without being there when you put it together.
    did you put no1 piston to tdc and same with cam gear?
    the cam gear has the notch at the top with the dowl pin type thing facing top.
    you put your wite marke on timing belt think one notch back on the cam gear where that little pin mark is.
    you then just set your rotor to the no one plug lead.......
    to set tdc take of top timing cover.
    get a mate to crank it until you line white line up with the little notch.once thats at the top thats tdc and then face rotor button to no1 plug
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    the mark is ment to be straight up the top man so your out 180 judging by the manual.. with 53 grooves on the belt bottom one is 0 on the mark on crank
    and 53 grooves up is mark on cam gear.
    VLC86's Avatar
    VL Calais
    Dec 2009
    Thanks Nath. Thats the picture I went on.
    I have done it all again tonight. But while working all day I got a flat battery so im just waiting for the battery to charge
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    ." I rotated the top pulley 180 degrees before puting it all back together, so the mark on the top pulley was facing directly down."
    U said above
    Notch is facing up in pic
    so 180 degrees out
    VLC86's Avatar
    VL Calais
    Dec 2009
    Quote Originally Posted by detox_nath83 View Post
    U said above
    so 180 degrees out
    Yeah thats where I have gone wrong. Hopefully that works
    Ill let you know
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Aug 2004
    timing, take the dizzy out and move it one tooth at a time untill it starts.
    VLC86's Avatar
    VL Calais
    Dec 2009
    Well I fixed the timing. But its still doing the exact same thing.
    Its just not starting up. Im sure I have done the timing right this time.
    I followed the diagram and gregories manual
    I will try to get a video trying to start it up.
    Aug 2004
    how do you know that the dizzy is in the correct location relative too the timing marks though, just because the camshaft and crank shaft are in phase doesnt mean that the timing is.
    your dizzy has to fire at the correct time of it to run other wise no love.
    VLC86's Avatar
    VL Calais
    Dec 2009
    oh ok. Thanks cracker. How can I check/fix the dizzy?
    The more detailed the description, the easier it will be for me.
    Thanks again
  15. #15
    vl commodore and vz ss
    Jun 2010
    remember as well with your dizzy if u have a new cam or a worked cam in there to advance it a few degrees other wise it wont fire up properly i had this problem as well as when i done mine one of the injectors wasnt seated properly and car wouldnt start make sure you have all ur sensors hooked up as well
  16. #16
    VLC86's Avatar
    VL Calais
    Dec 2009
    thanks bro.. no new cam for me though
  17. #17
    jetboy's Avatar
    jetboy is offline You learn til u die
    VT exec
    Feb 2010
    Gold Coast QLD
    To check your dizzy is in the right position , make sure engine is on top dead center i,e firing on number one . Remove the dizzy cap and make sure that the rotor button is pointing too number one lead ( theres a little tab inside the dizzy ) , if not take it out and turn it round till it does , just remember as u push the dizzy back in the rotor will turn slightly so it might take a few goes to get it right . Also check that you have the correct firing order , as in the way the dizzy spins to
  18. #18
    VLC86's Avatar
    VL Calais
    Dec 2009
    looks like i got the timing right this time. I moved the dizzy one tooth and it started up but it wont stay on unless im revving it a bit.
    Also it seems to be running quite lumpy, when it does actually start up.
    Any ideas?
  19. #19
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
  20. #20
    VLC86's Avatar
    VL Calais
    Dec 2009
    no i didnt. Im considering towing it to the mechanics to get them to finish it off from here. Cos im stumped.
    Another question, the new extractors I put on are getting realy really really really hot. Like actually smoking when I get the car running. Obviously there is no heatshied now cos it wont fit over the extractors but should it be getting this hot just from running the car for a minute or two?
  21. #21
    Nackerz's Avatar
    Jul 2009
    Ok I just had a read through all the thread..
    I think what you need to do is this...
    remove harmonic balancer, remover timing belt covers, remove timing belt.
    Then take your number 1 plug out, turn the motor over until the piston is dead at the top...Your mark on the cranck where balance goes, key way should be at top with timing mark to the bottom right (see pic above)
    Then you need to turn your cam pulley so that the dot on the cam gear is at the top. When this is at the top, you need to check that the cam is in the right position by looking at the rockers/valves...Be carefull not to put it 180 out
    now you need to put the timing belt on and make sure it is exactly 53 teeth from the bottom timing mark to the cam pulley mark.
    Put all covers back on and re-fit harmonic balancer. DO NOT TURN YOUR MOTOR OVER. Remove dizzy and re-fit it with the rotor pointing to number 1.
    Now it should start straight away providing you have the cam right an not 180 out.
    Now put a timing light on it, and set the timing to 15 degrees. Middle mark on the harmonic balancer.
    Hope this helps you mate.
  22. #22
    Nackerz's Avatar
    Jul 2009
    Quote Originally Posted by VLC86 View Post
    This is due to the timing being out, or grease/grime on them from your hands when fitted
  23. #23
    VLC86's Avatar
    VL Calais
    Dec 2009
    Oh ok. I thought it could be burning off some of the gunk on it.
    I might try to get the car down there tomoro
  24. #24
    Nackerz's Avatar
    Jul 2009
  25. #25
    Nackerz's Avatar
    Jul 2009
    too bad your in bris. I would come and fix it for you and show you how to do it
  1. Head reco
    By reaper01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-07-2010, 08:41 PM
  2. VS Commodore, key head not starting car
    By J.T in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-05-2010, 12:29 PM
  3. Reco?
    By ianf in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-10-2007, 06:49 PM
  4. VS Reco
    By ducatis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2006, 09:46 AM
  5. Reco Vn V6
    By G3MINI in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-02-2004, 08:21 AM
