Hi everyone, im just wondering if anyone can tell me where this hose (in pics) is ment to goto?
My VL is running ruff like its missing or something. in neutral it idles fine but reving it slightly and it almost conks out. ive checked all the basic things (plugs, leads, injectors etc) and that hasn't solved it. i found this hose and i have blocked it off for now which has made the car run a little better, but i really want to know where its ment to go. Any help is appreciated. Cheers Paul.![]()
Also them leads look screwed! I would replace them. Number 6 looks really bad and will be getting very weak spark to the plug.
Hey mate Thanks alot for your help i connected it now!! ive got another question if you could help me with that would be great. First of all what is this? and where is the hose coming from it ment to connect to? See pic. Cheers.
Bump**********
vacuum ball storage tank , also known as a soccer ball
Thanx for that mate. and do you know where the hose coming from the soccer ball connects to? cheers.
hi there i found that one out the hard way. it goes to and operates your heater flap controls
