Results 1 to 10 of 10
Thread: problems help
    vl commodore and vz ss
    Jun 2010
    Default problems help
    hi guys i have just had my head done on my rb30 fully tuned and installed by my mechanic and now hes stumped because first my water pump went then radiator crackd just fixed that started it up and snapped a piston ring is it common for everything to go at one in the rb30 because i havnt heard of it before or is it just one thing causeing these problems any help would be much appreciated
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    one thing, S*IT Mechanic......
    weird for a ring to snap.. how the ringland
    usually detonation cracks ring lands or rings themselves.
    Water-pump and radiator could be just coincidence man
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    if piston is damaged on top surface like it has rapidly cooled and has chunks missing it could be a coolant leak into the bore
    e.g. incorrectly installed headgasket or warped head (not tensioned down correclty OR heat warped)
    radiator was old then coincidence if radiator was brand new then i would say related
    Jun 2010
    cheers guys dont think it would be a warped head it brand new cost over 1000 bux in work on it
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    its hard to diagnose things like this unless you have checked compression is good first before dismantling!~
    oh and rings shouldnt snap with correct installation e.g right way up~!
    Jun 2010
    cheers checked compresion this morning and 6 is very low thanks for all the help just figured it be easier to chuck it on blocks for a few months on my way out to pick up an rb 25 to chuck in it thanks again
    jetboy's Avatar
    jetboy is offline You learn til u die
    VT exec
    Feb 2010
    Gold Coast QLD
    See this happen all the time , chuck a new head on an old engine , an everything else falls apart .
    At 43 a wealth of info , but still heaps to learn
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    This sort of thing happens a lot. New head gives better compression which puts more load on rings and bearings. If the rings had a bit of wear in them then they will fail. If the radiator cracked and the waterpump failed as you said, then it is quite likely that the new head has cracked or warped from the heat. Piston rings will loose their tension and leak if they get too hot also.
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    if on ly one cyclinder down dont assume its the head (not that this matters with rb25 replacement)
    could be the tp of the block on number six is not flat
    remove head and check with a straight edge
    or
    incorrectly fitted or damaged gasket
    either could cause coolant entrance into the bore especially on 1 or 6
    Jun 2010
    thanks heaps again guys car is goin on blocks this arvo new motor is on the stand getting stripped and fully rebuilt guess im sorted for xmas break thanks again have a good xmas drive safe
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. VZ SS random problems starting and also lock problems.
    By alista in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2010, 11:23 PM
  3. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  4. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  5. Problems With My VT
    By sno in forum V6 Development And Modification
    Last Post: 25-12-2005, 07:10 PM
