Results 1 to 4 of 4
Thread: Oil press with modded bottom end
    Vl turbo/ vn supercharged
    Apr 2008
    Kwinana, Perth
    Default Oil press with modded bottom end
    G'day, my bottom end clearances are larger than standard. 2.5 thou on the Mains and 2.75 on the conrods. Oil feed holes have been opened up to 7mm. With the standard 80psi oil pump press, Will the press drop much due to the larger clearances? Cheers.
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    as in .0025mm? anyway there will be a drop due to less constriction
    you would need to talk to an engine reconditioner to find out if there will still be enough pressure to get oil to the rest of the motor
    as you know when bottom end clearances die the oil pressure drops to next to nothing
    would at least recomend you get an oil pressure gauge fitted so you know its not 0psi!~
    Apr 2008
    Kwinana, Perth
    Yeh a gauge is a must, and I'm fitting a nitto adj press oil pump. I'm hoping these specs r a good thing. They Should be, as they came from Kyle(6boost), and he seems to know his s**t.
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    yeah he has a service manual if its the person im thinking of!~
  1. oil press reading on 202 VH
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-12-2009, 04:55 PM
  2. Where to buy V6 Oil Press sensor
    By VZnut in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-08-2009, 06:02 PM
  3. press remote once driver door up press again back down wtf
    By jarred193 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2007, 10:35 AM
  4. turbo v6 , l67 bottom end or rebuilt ecotech bottom end?
    By petezor in forum V6 Development And Modification
    Last Post: 25-01-2007, 12:16 AM
  5. 'Press Remote' ?
    By Swift in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-07-2006, 11:01 PM
