hey guys im having a bit of difficulty fitting the centre top mould on the front bar of my vl
has anyone got any pics of the fitment of the mould
the part im having trouble with is the two small brackets , that go on each side of the car.
any help would be great
cheers allan
anyone ???
doesnt it just slide in around the bolt heads and gets tightened down along the lights rail.
the 2 small trims just go under the indicator where there is a bolt head/nylon bit and then it screws in the other end infront of the tyre(screw head faces tyre on the small rolled section.
yer ive tried it but it dosnt seem to hold it down, the side moulds are easy, just the centre mould. its doing my head in. i might just have to go to the wreckers and take a few photos for reference
cheers for the help bud
i could get some pics tommorow for u but u may not be able to c the anchor points as this is how mine is put on.
any pics would be good
cheers mate
Ok man pics were hard, but had a good look in the centre part where your grill is there is 2 push in clips on the trim that push through a metal square hole and click in,. as for the anchors below the lights it just slides overthe points and clamps down on it.. for the ends of the trim infron the lights where the corner pieces fit there is a screw in the back so when put the 2 together u put the screw through it to brace it..
so the 2 centre clips hold it in and the others are guides and then the end angles hold it back.
Best i could get man sorry, tried pulling it back but didnt wanna snap it lol
hey mate thanks for taking the pics. im gonna have another crack at it on the weekend and if i still cant work it out. ill go to the wreckers and take some photos
cheers for the help mate
not a worry man goodluck let us know
