Results 1 to 12 of 12
Thread: how to upgrade and what to upgrade on my vl?
    87 model vl
    Jan 2011
    South Australia
    Default how to upgrade and what to upgrade on my vl?
    i have just bought my 87 model vl commdore and am wishing to upgrade the performance of it in anyway i can, was wondering how i could set up or where i could by a could air intake for it? whats the go with putting bigger cc fuel injectors in it? how to convert from drum brakes at the back to rotor disk brakes? atm its auto and non turbo but am looking to convert to manual asap ay help woukd be highly appreciated thanks.
    hears a pic of my vl when i first bought it
    vy2 clubsport
    Feb 2008
    adelaide
    convert it to 5speed
    service it
    exhaust
    forget injectors etc
    save save save
    VL Berlina (304 EFI 5spd Manual)
    Aug 2009
    New Zealand
    Yeap, forget injectors.. Really unnecessary as a stand alone upgrade. Probably the cheapest way to get discs on the back is to find a complete disc brake diff and swap it over. To find a good cold intake look on google and the search function on the forum itself is very helpful as well. One of these threads pops up every now and again, i'm sure someone has already answered these questions.
    Vl Under-bonnet Mods where 2 start ?
    ^^ Might help you.
    VB SL/E
    Dec 2008
    All else being serviceable ie compression is good and even, plugs leads dizzy good then Extractors, exhaust, and a tune, i have found alot of VL's have been mucked around with, setting the timing back to factory spec and setting ecu mixture correctly makes a big difference.
    Another thing is to get the fuel system pressure right, it is common for the reg or pump to fail over time, replacing them makes improvements too.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    87 model vl
    Jan 2011
    South Australia
    cheers everyone so OHZE pretty much if i got hold of a back end of a vn commy i would be able to convert the whole lot? ill have a proper read into it thanks heeps
    87 model vl
    Jan 2011
    South Australia
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    vy2 clubsport
    Feb 2008
    adelaide
    87 model vl
    Jan 2011
    South Australia
    im going to start doing the 5 speed conversion, extractors and exhuast, give it a service thanks for all the help
  1. vn upgrade to v8
    By donboy2000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-07-2010, 12:45 AM
  2. VZ Ute upgrade
    By 2005vzute in forum Car Audio
    Last Post: 02-07-2010, 11:35 PM
  3. What else to upgrade?
    By daz08 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2010, 01:47 PM
  4. bcm upgrade in vr HELP
    By kal666 in forum Electrical Wiring / Questions
    Last Post: 17-01-2010, 10:20 PM
  5. next upgrade?????????
    By holden_calais_VT_1999 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-11-2009, 07:54 PM
