Results 1 to 17 of 17
Thread: PLEASE HELP, VL Turbo noob here :-S
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    Default PLEASE HELP, VL Turbo noob here :-S
    hey guys when it comes to vl turbos or any turbo car i know stuff all about them so was wondering if someone could help me identify these parts and let me know what they are for, cheers
    i got 2 pics, one of something that was in the engine bay and looks like a mini blow off valve
    and the second one which is of the turbo and exhaust manifold, but the black hose goes from the turbo (1), to the wastegate (2), and the other arrow (3) is where the blue thing was in the engine bay, but it was bypassed when i bought it...
    so basically what i wanna know is what is the blue thing and why would it have been bypassed? the car has a front mount and has a blow off valve fitted to the cooler piping if that makes any difference, also on the other side of the blue thing it has a sticker that says " + BOOST - " which made me think it can somehow change the boost settings, meh, as i said ive never played with turbos before so if this is really simple stuff please excuse my ignorance :P
    cheers again,
    WAL3SY
    Going where no late model stato/caprice has gone before.... GAME ON!!
    vy2 clubsport
    Feb 2008
    adelaide
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    the blue thing is a boost controller. and basically does exactly that... Controls Boost
    u can manually turn up and down the boost to your desired liking, providing u know what u r doing.. if u boost too hi u will lean out and melt a piston.
    ... EDIT Bow u bet me by less than 30 seconds..l. And Dont screw your overflow bottle to your Fan Shroud LOL...
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    Yeah blue thing is a boost tee, the little nut restricts boost going to the turbos wastegate actuator and therefore it will open at a higher boost pressure. You can't unfortunately go lower boost then what the wastegate is set to open at, as you cant make it open earlier, only later.
    walesy's Avatar
    Jun 2005
    Perth SOR
    thanks for the reply guys is there any way of checking what size spring i have in the actuator? it has a part number so maybe ring a turbo joint and they might know? i wonder why the previous owner bypassed the manual boost controller then :-S
    also what boost does a stock VL turbo usually run and with a front mount what kinda boost could i possibly run?
    vy2 clubsport
    Feb 2008
    adelaide
    Quote Originally Posted by detox_nath83 View Post
    haha they are gooses on ct.if it was to heavy i wouldnt have had it there.it ways bout the same as a 600ml bottle of coke i think there just weak as piss.
    or you zip tie it.thats saffer
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    haha i know i had a read and a laugh man,,,
    i saw the noob who zip tied it.
    6Psi is standard man.. u can run 10psi safely on an a8... Heck im running 10psi on an N/A High-comp (turbo inj and Ecu and Front mount though) Timing 15 deg no pinging.
    Could have bypassed it coz either the controller was not accurate or was getting boost creep or something i dont know. or wanted to run what ever the wastegate was allowing it to run, so 6
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    Yeah sometimes boost controllers can cause additional lag too, If the previous owner was just wanting the 6psi then he may have bypassed it for that reason, it is MINIMAL though.
    Best way you can check your wastegate spring that i know of is to hook up a boost gauge and see at what point your boost stops without the boost controller connected. It'll most likely be 6-7psi.
    walesy's Avatar
    Jun 2005
    Perth SOR
    thanks guys i got a boost gauge in it but i pulled the turbo off to get it rebuilt and hi flowed, the seals had gone and i ended up with a shitload of oil in the intercooler :P
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    Quote Originally Posted by walesy View Post
    haha that sucks aye
    walesy's Avatar
    Jun 2005
    Perth SOR
    yeah especially when i was lying at the front of the car and pulled the bottom cooler hose off and got covered in it haha, i spose these are the things i will learn about these cars along the way :P
    walesy's Avatar
    Jun 2005
    Perth SOR
    also i got a price for it to be rebuilt/hi flowed they said $1300... is this a good price? went to a few different places and they all seemed to be about the same
    vy2 clubsport
    Feb 2008
    adelaide
    stuff that.
    buy a 35/40 or you could buy my old setup for nearly that price,hi flowd with hi mount,fmic,custom plenum etc
    walesy's Avatar
    Jun 2005
    Perth SOR
    whats your old setup? bear in mind this is my daily so dont wanna go crazy on it yet, 35/40 is a bit laggy for an auto
  15. #15
    vy2 clubsport
    Feb 2008
    adelaide
    any turbo car id propably sugest a stall converter.
    - Extreme Turbo Manifolds Plenum
    - xf throttle
    - 440cc GTR injectors
    - Monsta High Mount Exhaust Manifold
    - T3/4 Highflow Turbo
    - T04 .06 Comp Cover
    - T04 H –Trim 58mm Front Wheel
    - Sierra Cosworth Exhaust Wheel
    - Modified VLT Exhaust Housing
    - oil and water lines
    - banjo bolt
    - dose pipe
    - 3 Inch Intercooler
    - cooler piping to suit plenum
  16. #16
    Aug 2007
    Newcasstle
  17. #17
    walesy's Avatar
    Jun 2005
    Perth SOR
    ok sweet ill try find it, if you find it before i do can u post a link here please?
  1. Help a noob out. LOL
    By Macca86 in forum Car Audio
    Last Post: 16-05-2010, 06:10 PM
  2. Noob here
    By mi04se1 in forum VE - WM
    Last Post: 28-11-2009, 02:30 AM
  3. noob with a Q
    By final_drive220 in forum The Pub
    Last Post: 08-10-2008, 03:57 PM
  4. Any Help for a noob?
    By ProMaX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-08-2005, 11:34 PM
