Results 1 to 4 of 4
Thread: VL berlina non turbo help
    Holden VP wagon - http://forums.justcommodores.com
    Sep 2009
    Default VL berlina non turbo help
    hey i just baught a vl, used to be a turbo, had a new engine put in without a turbo
    on the way home from buying it thought i might give it a bit but wont go over 2500rpm
    if i use the shifter and put it in first it will go past 2500rpm but not when its in drive,
    does this have a rev limiter or something in it, not sure what to do
    this question might have been asked but im new to the VL's
    thanks
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    possibly airflow meter man.
    or Fail safe mode(limp home feature)
    But pull the codes from the ECU and let me know what u get... Follow the How too in my Signature below
    VL Commo sometimes
    May 2010
    Campbelltown
    Sounds like a few wires for the Auto trans computer weren't reconnected properly.
    All VL stock ECU's have a rev limit, the 3EA/3TA are set at 6400rpm and the 3TA/3TM are 6600rpm if I recall correctly.
    The Stock ECU also go in to a fail safe rev limit when specific sensors go out of range. The rev limit introduced is around 3300rpm
    It might pay off to grab a workshop manual and check the Trans selector switch as it can causes shift problems in the later model transmissions.
    Hope this helps
    Sime
    http://www.stocketune.com
    tuners@stocketune.com
    ECU Calibration Engineer -Tuner
    Sep 2009
    Thanks for the info I will try all those things out tomorrow, I'll get some picks going and tell you how it went
  1. [SA] VL Berlina Turbo
    By VL Berlina 5speed in forum Vehicles For Sale
    Last Post: 14-01-2011, 08:40 PM
  2. Vl berlina turbo, gt35
    By cracker in forum VL
    Last Post: 21-12-2010, 11:05 PM
  3. Turbo conversion of 87' vl berlina
    By vlcosson in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-11-2008, 04:41 PM
  4. VL Berlina Turbo
    By tuckerbag in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-09-2008, 01:57 PM
  5. VL Berlina turbo
    By wagonb0y in forum VL
    Last Post: 03-11-2006, 06:06 PM
