Are all tailshafts the same?
I am putting a vl diff in my VK and it runs a supra 5 speed.
Which tailshaft do i need if they are different.
cheers Boschvette
All aren't the same they are different lengths. Some are the same but I cant say for sure about VK to VL.
You need to take the front off the tail shaft (gear-box end) and the rear (diff end) to a fabricator, or experienced mechanic, tell them what your using it for, they may require some measurements, other than that, the rear end of the tail shaft will bolt straight onto your diff.![]()
The salisbury diff has u-bolts holding the tailshaft to the diff....
The borgwarner diff has a flat plate with 4 bolts holding the tailshaft to the diff.
