Results 1 to 4 of 4
Thread: VL V8 Air Con & Alternator mountings
    '87 VL V8 Berlina
    Jan 2011
    Queensland
    Default VL V8 Air Con & Alternator mountings
    Hi All,
    I have a VL sedan, with black 308 block but now has VS fuel injected heads. The engine bay was dismantled when i purchased it, and we're now up to the stage of re-mounting the air con and alternator. I know the A/C is mounted on the drivers side at the top and the Alternator sits below it, but the mounts that were with the car don't seem to match up. Not sure if this is due to the different heads or if there are pieces of the mounts missing.
    If someone can help or provide some pics/links on how they should be fitted, it would be great.
    vy2 clubsport
    Feb 2008
    adelaide
    alternator sits on passenger side on a vn-vt 5ltr
    power steer sits on passenger side on vn-vt 5ltr
    im sure air con sits on passenger side on vn-vt 5ltr
    try google bud
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Yes but he has a vl block with vs heads so it sits all drivers side check that ur using the correct bracket
    VL V8 & supercharged VX
    Nov 2006
    western vic
    mmmm u would think i would fit cos u can use both sides on the vl heads maybe the bolt studs are different on the vs heads even the bolt thread maybe
  1. 6x9 ute mountings
    By VS-S-PACK-UTE in forum General
    Last Post: 21-12-2009, 05:53 PM
  2. Alternator not charging, no alternator light
    By 5L fury in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2009, 05:55 PM
  3. V6 Alternator
    By bush_basha in forum Parts And Other Items For Sale
    Last Post: 20-10-2006, 05:49 PM
  4. Alternator Help
    By ICUBYE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2006, 09:18 PM
  5. Alternator maybe??
    By VT97 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-04-2006, 01:49 PM
