Results 1 to 9 of 9
Thread: VL wont start, have spark, have fuel, not cas
    VL Commodore
    Jan 2011
    Newcastle
    Default VL wont start, have spark, have fuel, not cas
    Hey guys so no-one wants to take me serious because im a female so im having trouble getting through to mechanics.
    My Vl just died while driving. Didnt stall it was like it ran out of petrol but it didnt. Towed it home to find it has spark, it has fuel pressure, fuel pumps are priming. Had a mechanic come out to say it was dizzy. Replaced the dizzy twice, still nothing. Couple of people said its the cas but the cas is inside the dizzy so if it is we have 3 dud cas here. All relays are fine. Tried a second computer and still the same thing. Computer is giving error code 11 cas but like I said we have tried 3 now.
    Only thing we can find is that it has no injector pulse. It tries to start and sounds normal it just wont fire. It will just sit there and wind until the battery dies.
    I am absolutely stumped. Any suggestions? I sware we have tried everything.
    vy2 clubsport
    Feb 2008
    adelaide
    i noticed you said you tryd 3 cas's. did you change cas or whole dizzy?if whole dizzy maybe timings out
    VL Commodore
    Jan 2011
    Newcastle
    Changed whole dizzy but timing is right. Well should be.
    Would timing stop injector pulse?
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    No timing will not worry injector pulse...
    How about the Cas Plug on top,, i have had this b4 and many have experienced this as well have a good look at the plug and pull back the rubber boot and inspect the wires.. where they r crimped to the spade connectors.
    I found one of my problems was corroded out and a wire was broken.
    Give it a good spray with wd40 or INOX
    Goodluck,
    VL Commodore
    Jan 2011
    Newcastle
    Ok we have now tried a whole new wiring harness and still have the same problem...
    vy2 clubsport
    Feb 2008
    adelaide
    VL Commo sometimes
    May 2010
    Campbelltown
    VZ Adventra, HT Monaro GTS
    Jan 2011
    NZ
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    How much fuel is in it? My mates vl died one night, turned out it wasn't enough fuel in the tank. Put fuel in and started straight away...
    Mmm Injector pulse, The ecu that you tried, was that from a running car? Might be caused by the timing as the cas tells the computer when to squirt fuel in and when to spark etc.
    How have you gone with it? Updates on your progress?
    Cheers Nackerz
  1. EFI VK won't start but has fuel and spark...
    By '88 VN Custom in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-08-2010, 11:05 PM
  2. V8 Wont start after Installing new Spark Plug Leads :(
    By commycrew in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2010, 06:45 PM
  3. VS 5 litre UTE wont start (weak spark?)
    By shadow6ix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2010, 04:44 PM
  4. VT SS Cranks but no spark/wont start
    By heyman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-01-2010, 12:35 AM
  5. car wont start no spark
    By sli-rb in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-09-2009, 09:10 PM
