Hey i want to upgrade the turbo on my vl. I have a top mount manifold to go on also. Jsut need help on what sort of turbo to upgrade to and what will fit. If anyone has one they want to sell please let me know thanks
internal gated/external?
go a gt35/40 or a To4e External gated as well
internal or external gated
just got a gt35. will i need to run an aftermarket ecu or will the standard one run it ok
depends on boost man....
Turbo is independent what figures u wanna run....
If u say put 10psi hyperthetically use the Turbo ecu and injectors. if u wanna go over say 15(where turbo Ecu and Inj Max out will cause a lean out) u would go aftermarket ecu ,injectors and Afm etc etc.
mt turbo injectors were maxed out at 182rwkw on 7psi of boost from a gt35 with a baby cam, upper rpm is was rather lean around 14.5 afr's
if your computer and injectors are standard, run as little boost as you can.
cheers
cracker what is a good and safe AFR's range.. around 10-12???
