Hi I have VN V8 motor and T700R4 box in a VL
Im after a memcal to suit my mods if possiable as i live to far from perth (700kms) and live on a farm so no time to get there
Standard stroke 304 with 10-5.1 compression, fully ported and polish VN heads, 1.65 to 1 crane roller rockers, crane solid cam part number-883671 the spec card is at the end of the email also has bosch blue top injectors 775, peter starr manifold 90mm, dominator 3500 stally with lock-up which i would like to lock up at 100kph not before if possiable and a 3.9:1 spooled diff.
can i get a price if possiable and what sort of power would i be looking at.
Thanks![]()
Any info would be great
Part Number: 883671 Grind Number: F-280-2
Engine Identification:
Start Yr. End Yr. Make Cyl Description
Engine Size Configuration
Valve Setting: Intake .026 Exhaust .026 HOT
Lift: Intake @Cam 3454 @Valve 553 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 3514 @Valve 562
Rocker Arm Ratio 1.60
Cam Timing: TAPPET @.020
Lift: Opens Closes ADV Duration
Intake 31.0 BTDC 69.0 ABDC 280.0 °
Exhaust 71.0 BBDC 33.0 ATDC 284.0 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99893
Loads Closed 130 LBS @ 1.850 or 1 27/32
Open 326 LBS @ 1.330
Recommended RPM range with matching components
Minimum RPM 3500
Maximum RPM 7200
Valve Float 7800
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 16.0 BTDC 48.0 ABDC 105 244.0 °
Exhaust 56.0 BBDC 12.0 ATDC 113 248.0 °
Remarks:
INTAKE CAM LIFT AT TDC = .100" CAMSHAFT IS GROUND WITH .0015" LOBE TAPER.
