Originally Posted by
[REDHOT]
I'm not quite sure what caused it to start happening, at first i thought it was someone tried to break in. Because I woke up one morning to find all the doors unlocked, and making a wierd buzzing noise.
I couldn't figure out what it was at first, but the battery was dead and when I tried to lock the door with the key, and it stopped. Long story short got the car started and went for a wuick drive and the doors were locking and unlocking by themselves nonstop (this must be what kills the battery).
I get home and the drivers side lock doesnt work (can stick the key in but wont turn), and every time you lock the car from the inside the locks play up again, so I went over to the passenger side and locked it via that lock and everything worked fine.
It worked fine for the past few days until this morning I woke up, same thing happened again. Batterys flat locks are unlocked.
As far as electrics go I have no clue, the only things I can think of is someone tried to break into the car or as it was a rainy night (same as last night) water somehow got on the fuses. I honestly have no clue, the car also has solex locks so that may have something to do with it ? or it may juust be the age of the electrics.
Any help at all would be greatly appreciated, I just want to know what is causing it or what can be done to fix it. Even if you've heard of this happening before.
Thanks
