Results 1 to 16 of 16
Thread: running lean
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Default running lean
    my n/a vl is running lean at full throttle, is there anyway to fix it?
    jetspin_vn's Avatar
    jetspin_vn is offline JetSpin Racing Team
    VN GTS
    Nov 2003
    Mission Bay, Auckland, New Zealand
    You know this how? There is a screw on the AFM that with careful tweaking (also involving some messing with the PCV valve) can be used to adjust the mixture, but what makes you think it's lean? Detonation perhaps? (Pinking noise) try resetting your timing to 15 degrees BTDC first dude.
    JetSpin Racing Team Mantre:
    "F**k safety, I'm in a hurry"
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    i got it dyno'd. if i tweak AFM it will run rich over the entire rev range. i need to adjust it at full throttle somehow.
    VL Berlina soon to be turbo'd
    Mar 2005
    Whyalla ..
    Default surges
    hi there my vl surgers on full throttall what would that be ? and has very bad misses i change the spark plugs and thay fowl up in 30 min >?
    i also put new leads on it too the car starts and runs sounds like a tractor and thats not good what could it be ? any help would be appreciated
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Surging at high revs.. Fouling plugs.. Obviously running rich.. Why I'm not sure.
    Whats your timing at?
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    I had this same problem a while back...
    i found out the hard way that it was my AFM was on its way out...
    got it replaced with a new one about $200 i think in a service..bloody expensive but now runs like a dream
    ........just a thought
    stock_vl is offline wh internationals?
    vl calais 3.0L
    Apr 2005
    Tocumwal/isolated
    im thinking im gunna buy a new afm just for the sake of it!!
    my exhaust tip always seems to be black!!
    like she smokes worse then my old man (smoked rollies since 13) thats damn terrible!!
    this more then likely what it is?
    I CANT WALK ON WATER BUT I CAN STUMBLE ON ALCOHOL
    vl berlina wagon 6cyl
    Jul 2005
    its normal for the exhaust pipe to be black inside on unleaded
    does anyone know if the exhaust can be read to show whether its running rich or lean?
    BTW, on LRP the exhaust should be a dark mottled grey
    Bax
    Nothing
    Jan 2004
    QLD
    VL Crapbox
    May 2005
    i run mine on metho Bex, if i run out, distilled water.
    If you want more inches, STROKE IT!
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    Quote Originally Posted by harry3
    Go down to a dyno shop. they stick a sensor up the pipe and test it at different rev ranges. its how i found out mine is running lean at full throttle.
    VL Crapbox
    May 2005
    lean as opposed to other normal VL's they have run on the Dyno stock or... If they told you it was running lean, did they have some explanation to back it up? Can you tell us what the reading was at all. I haven't Dyno'd my crapper so i dont know what it would be.
    Was it constant every time they ran it, maybe injectors dont flow full range due to blockage... maybe fuel pump not working to best it can but was this an issue that made you take it to them, did you notice a lack of power at warp acceleration?
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    they said it MIGHT be the AFM. they didn't want to adjust the AFM as it would then run rich the rest of the rev range. the fuel flow is good. i wonder if its cos i took both mesh out of AFM? no idea!
  15. #15
    holdensupporter2005's Avatar
    holdensupporter2005 is offline Donating Member
    VE SV6 Commodore - Silver
    Sep 2005
    N.E. Vic
    Test your AFM
    1. Grab a multimeter.
    2. set it to ohms Ω
    3. unplug the cable that goes to your AFM
    4. hold the multimeter probes on pin 1 and 6 of AFM
    5. turn the adjusting screw on your AFM until you get a reading of 382 ohm (this is factory default setting).
    6. plug your AFM back in.
  16. #16
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Default rich
    Sounds like AMF dude...
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
  1. rich or lean
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-02-2006, 09:57 AM
  2. Running Lean Under Load
    By riggers26 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-08-2005, 06:39 PM
  3. running lean code
    By driveberlina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2005, 11:09 AM
  4. i wont to lean more about VLs
    By aslan in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-10-2004, 10:23 AM
