Results 1 to 23 of 23
Thread: changed motor & wont start
    vl commodore
    Apr 2010
    Default changed motor & wont start
    i just got a good running motor that started first time every time from a beat up vl and put it in my vl but now it wont start, i dont know what to do because it ran perfect in the old vl but as soon as i put it in mine it wont fire up? what do i need to look at replacing?
    cheers
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    Does it turn over? Is everything connected properly? Need more detail.
    Best RPG ever
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I would say you have either missed something plugging it all together or maybe a fuse has blown. Double check EVERYTHING.
    Visit my Facebook page
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Could of just missed something like an earth or connected the leads up wrong on the dizzy (I'm assuming the VL's have a Dizzy?)
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    vl commodore
    Apr 2010
    it turns over but wont start and i think the ecu is giving me false codes here are the codes its showing. 11, 12, 14, 21, 23, 24, 31, 32,
    but i know theres nothing wrong with the starter motor or air flow meter because they are both brand new
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Reset the ECU and run a diagnostic again..
    are u getting fuel?? Hoses arnt on wrong?? as in return is on the inlet
    are u getting spark?
    Process of elimination
    CAS failing???
    vl commodore
    Apr 2010
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    it is bound to be a minor oversight E.G some connection somewhere as has been suggested above.
    the motor swap was auto to auto, manual to auto or vise versa? it maybe a wire loom or neutral safety switch problem.
    Nobody wants to play with me
    vy2 clubsport
    Feb 2008
    adelaide
    vl commodore
    Apr 2010
    it was auto to auto
    i didnt end up getting my car back home lastnight so i cant do anything yet but hopefuly getting it back 2nite or 2morro morning
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    auto to auto, it must be a SIMPLE oversight, Keep us posted!
    vl commodore
    Apr 2010
    hey guys sorry i took so long to reply ive been working flat out and havent had much time to do anything else
    now that work has slowed down a bit i had a chance to look at my car and i found that the fuel pump was stuffed and it had no spark so i got a fuel pump and CAS from a wreckers
    now it has good spark and its getting fuel i made sure the hoses are on the right way aswell but it still WONT START
    VL Berlina soon to be turbo'd
    Mar 2005
    Whyalla ..
    Default vl
    i had sim problem when i replaced my wireing loom, had spark and fuel, turned out to be
    the grounds on the drivers side of the block not getting good contact also timing was 180
    degrees out does it sound like it wants to fire then dies and so on? bit more info on what
    else you have tryed would be nice
    but yea check for broken/cracked hoses good grounds/connections, spray some contact
    cleaner on connections reset ecu recheck codes, try your old ecu , recheck timing,
    replace the relays fuses out of old car that ran , maby replace the + temanal lead in
    wireing loom has a resistor in it or what ever its called check the afm hasnt broken its
    thin wire inside , check afm omhs with multymeater,voltage from cas, could be many other things to check
    but im typing with the on screen
    keybord and it sucks lol good luck n let us know ur progress they helped me start my vl
    here , between all of us im sure we can diagnose ur vls probs with a bit more info
    vl commodore
    Apr 2010
    faulty CAS, fixed that
    faulty fuel pump, fixed that
    it doesnt sound like it wants to start at all the motor just keeps turning and turning
    and i took the gas tank out because it was out of date but the wires are still connected not sure if that could have something to do with it
    i should probly tell you guys that the old fuel pump had dark petrol with heaps of metal shavings in it aswell
    thats all i have tryed so far but ill be putting other things aside so i can get more things done on this friggen bitch!..
    im not working 2moro so ill get around to doing most of the things the "muff" has mentioned haha
    thanks muffman and everyone else ill keep you posted daily this time
  15. #15
    vl commodore
    Apr 2010
    today i found out it has no injector pulse and a fuse was missing on a wire that comes out of the wiring loom that is connected to a relay near the drivers side head light
    but i couldnt see if that was the problem because before i even seen it it was missing
    my brother tryed putting some petrol in through the throttle body and seeing if it starts
    but now the starter motor just clicks and doesnt turn the motor
    my brother said it is just vapour locked but i am not a machanic so i cant tell the difference
    also checked all the grounds for bad connections and hoses for leaks and it all seems ok
    is there a relay for the injectors and is it near the drivers side headlight?
    either way its for something and needs another fuse
  16. #16
    Road trawling paddock bomb = moody VL
    Jul 2009
    goldfields VIC
    if it was on dual fuel did you just take out the changeover switch and not do anything with the wires from the back (i think one says power one says gas one says fuel and the other is earth)?
  17. #17
    vl commodore
    Apr 2010
    i only took out the gas tank and left the rest of the wires the way they were but my brother was playing around with them yesturday and disconnected the positive wire from the battery
  18. #18
    vl commodore
    Apr 2010
    i got the car started for about 10 seconds because of the petrol my brother put in the throttle body but after that it wouldnt even try to start
    he said that my injectors arent working because the gas was disconnected and the ecu cant tell the injectors to turn on and pulsate or something like that
    is he rite and if so how do i go about fixing it? should i take out all of the gas wires?
    just thought id ask here and see if anyone knows before i take it to and electrician
  19. #19
    VL Series 200 , 85 VK Berlina, VL Executive Wagon
    Apr 2010
    those error codes you gave is what you are meant to get when you start a diagnostic. you then have to cancel them by depressing the accellerator pedal, turning the aircon on and off, shifting from park to neutal back into park then start car and drive over 10kph and recheck codes. your problem is probably doesnt have a code though. mine did the same thing. hold the ignition on so u can hear the pump priming then spray some aerosol spray up the intake then quickly put it back together and turn the key. making sure the afm is connected properly. thats what worked for me. give it a couple of goes and if it starts leave it running for a bit.
  20. #20
    vl commodore
    Apr 2010
    nah its definately the injectors i just took the fuel rail off with the injectors still on it and tryed to start it and no petrol came out then i took the injectors off the fuel rail and tryd to start it and petrol was coming out so i think its got something to do with the gas wires
    would a new wiring loom fix this?
    i was doing what you said all day yesturday but with petrol and it just kept stalling as soon as the petrol ran out
  21. #21
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
  22. #22
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Check the injectors are pulsing with a multimeter.
    I'd say it is on gas mode and the injectors are switched off. You need to bypass the injector cutoff relay, or wire it back up and put the petrol/LPG switch on petrol.
  23. #23
    vl commodore
    Apr 2010
    thank you to all the people that helped me out, i got it running today
    it was already switched to petrol so i thought id try the oppisite and hook the gas wires back up and switch it to gas the idiot that installed it must of wired it up wrong because it worked
    thanks again everyone
  1. HELP Vp wont start, starter motor trouble
    By duffysmashrepairs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-01-2011, 02:14 PM
  2. vt wont start (immobiliser or starter motor) please help.
    By evilhighway in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-08-2010, 08:55 AM
  3. VT wont start ??? starter motor ??
    By Miss L in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-08-2010, 08:04 PM
  4. Black motor 202 carby wont start
    By brades in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-05-2010, 06:52 PM
  5. Motor turns over but wont start...
    By Stellaman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2009, 09:36 PM
