New member - treat me gently!
I have just put a new ignition barrel into my 1988 VL and found the information in this forum most helpful.
My problem is that neither the old barrel or the new one will turn to the Accessory position.
Out of the column, both barrels turn to the Accessory position easily, but as soon as I put them in they won't go past the Off position.
Any ideas would be appreciated!
if you replaced it with a NEW barrel I would say your ignition switch (not the barrel) is worn.
Nobody wants to play with me
it may be the switch.
also my mates car did a similar thing ended up being the rod parton the side of the steering column, itd slipped out of its position and wouldnt allow you to turn the key past a certain point
"The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
apparently wasting my time with 97 cubic inches
milk doesnt come in 1.6 litres
my geminis
