Results 1 to 8 of 8
Thread: Any tipe to avoid a cracked head?
    87RB30VL's Avatar
    87RB30VL is online now Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    Default Any tipe to avoid a cracked head?
    Edit: I friggin' hate it when I typo in a thread title
    So I read somewhere that the RB30's that went into the Holdens were more prone to getting their heads cracked than their Nissan counterparts as the radiator in the VL's are mounted lower than in the Skylines. Anyone got any tips or hints to avoid getting your head split, especially in this hot Aussie weather?
    I'm thinking along the lines of custom intakes or modifications to the intake/mods to make the airflow better etc
    cheers,
    Sorry if this has been covered, I searched but nothing came up.
    |8|7|R|B|3|0|V|L|
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    First Tip is to bleed the air out of the cooling sustem.
    second tip use a good anticorrosion radiator fluid
    End Tips
    Its really simple they wont crack if you maintain your cooling ssystem
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Ah ok sweet, I was hoping it wouldn't be one of those design flaws which makes a disaster inevitable
    |8|7|R|B|3|0|V|L|
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    Asked and answered perfectly.
    maintain your cooling system correctly and you will have no problems.
    Nobody wants to play with me
    vl berlina wagon 6cyl
    Jul 2005
    the holden engine had to be lowered at the front to fit under the bonnet and this somehow caused the steam trap head cracking problem.both nissan and holden versions have 2 bleeder bolts that must be unscrewed ( if siezed up, remove rubber elbow instead) and force water in thru radiator filler cap until water flows from both bleeder holes, put grease on bolt threads and replace
    vy2 clubsport
    Feb 2008
    adelaide
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by harry3 View Post
    Mate they didnt lower the engine its the radiator that sits lower. It makes the head the highest point in the cooling system. Air lighter than water so it rises to the top. Which mean your air pockets end up in the head
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Harry, where abouts are these bolts located?
    |8|7|R|B|3|0|V|L|
  1. Cracked head? blown head gasket???
    By VL_5SPEED in forum General
    Last Post: 09-01-2010, 10:41 AM
  2. cracked head?
    By ianf in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-07-2009, 05:19 PM
  3. cracked head
    By danos in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-07-2006, 10:19 AM
  4. Blown head gasket or cracked head
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2006, 07:52 PM
  5. Cracked Head?
    By Joshy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-04-2004, 04:11 PM
