Results 1 to 16 of 16
Thread: VL stalling and backfiring on cold start
    VL berlina
    Dec 2009
    Default VL stalling and backfiring on cold start
    Hey, i just bought another vl and it has a problem. when i go to start the car up in the morning, id let the fuel pump suck the fuel for about 10 secs or so as we do then start her up. it starts fine but when you go to give it anything it just is crap, will take a few seconds before it starts revving and backfires like crazy. its like its not getting fuel because if i plant it it will just stall. when it heats up it runs fine though, another thing is when i rev the car from the engine bay it doesnt idle properly until i rev it from inside the car which is strange. ive changed over the air flow meeter from my other car and a temprature sensor but hasnt done anything. i want to get this fixed asap because its a real pain.
    87RB30VL's Avatar
    87RB30VL is online now Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    So what you're saying is that when you start her up from cold, unless you wait till' she's hot, it just dies and backfires etc? From what I know, my 83 ute does that unless I hold the manual choke out until she's hot, then it idles fine, otherwise it just stalls but never backfires,
    |8|7|R|B|3|0|V|L|
    VL berlina
    Dec 2009
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Next time it's cold, just wait until it's hot (around 5 - 10 mins. I have a temp gauge to make it easier to see when she's ready) and then try a few small revs etc and see if it's all normal, cos if everything runs fine, you just have to wait till' she warms up everytime you start her cold
    |8|7|R|B|3|0|V|L|
    VL berlina
    Dec 2009
    Yeah thats what seems to happen. its so different from my other VL though?
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Yeah it seems strange as mine starts and runs fine even on cold starts. Maybe get your coil packs checked? I'm stumped on this one, i've only owned my VL for a few weeks and I used to be a ricer haha so i'm learning as I go
    |8|7|R|B|3|0|V|L|
    VL berlina
    Dec 2009
    Im going to the mechanic tomrorow to swap over my distributor and cas plug as my other vl had this just put on.... so its 1 month old. also swapping the cat converter which was on it aswell. ill see how we go and update it !
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    AFM or coolant Temp sensor... i rekon afm is starting to fail.
    do the swaps yourself its easy. and u will save cash. :P
    could b CAS starting to fail as well... start on the cheapest first and work up along thbe lines so to speak
    VL berlina
    Dec 2009
    Hey since i have 2 vl's i did swap afm and cts, wasnt that so i took both cars to mechanic and swapped the dizzys over and got a new plug in it. i pick it up tomorrow so ill see if its fixed.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Try changing the air regulator, which is at the front of the inlet manifold. It is supposed to help your engine run better when cold. It could even be the hose from the air regulator to the plenum chamber blocked with crap.
    VL berlina
    Dec 2009
    I got them back....it wasnt the CAS i swapped whole dizzy and put a new pllug, didnt do anything so im going to change injectors and throttle body over...
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    VL berlina
    Dec 2009
    ok its giving me the shits now, im going to get my injectors and throttle body swapped over depending how much its going to cost. ill see how i go next week
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Have you checked the cold start valve on the front of the motor? You should be able to see through it, if you cant, then it's stuffed.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
  15. #15
    VL berlina
    Dec 2009
    ill have to check that, i took the whole throttle body and sensor off my other vl (working) and cleaned the throttle body...when its warm there was noticable difference but its still the same on cold starts. havent done injectors yet thats going to be next.
  16. #16
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    I had the same issue with my r31 skyline. It turned out to be the Air Regulator was shut.
    Air Regulator - R31info
    I dont know if vl's have them but, undo the small nut in the picture, put a screwdriver in the air regulator and pull the nut towards the front of the car, then tighten it up. Hope it makes sense.
    Fixed my issues.
  1. VX Berlina backfiring, stalling and other weird stuff ( LPG)
    By Serija in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-08-2010, 11:23 PM
  2. LPG problem - wont start and backfiring - help needed
    By VRcommondoor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2010, 02:14 PM
  3. EFI 202 stalling when cold.
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-12-2006, 02:31 PM
  4. problems with backfiring and stalling on VP!
    By -**wHiStLe**- in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-05-2006, 07:05 PM
  5. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
