Results 1 to 7 of 7
Thread: vl diff question
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    Default vl diff question
    hey guys,
    i have a drum brake diff under my vl now,i have just brought a vl disc brake diff of a pretty Dodge bloke,
    just wanted to know if any one has put disc brakes etc straight onto the drum diff do they just swap straight over?
    or am i better of putting in the new diff?
    thanks.
    My VL Walkinshaw replica project
    VL 5L
    Jan 2011
    cairns
    dude i did the same thing kinda. i had drums and found a v8 vk diff and it took less then a day to put it in my car..........only prob i had was tail shaft but if urs is from a vl then u wont have that prob. i just swap the whole diff over heaps easier. after u disconnect the hand brake cable and undo the shocks and tail shaft its only about 4 or so bolts and its out. keep in mind u will need to swap ur hand brake cable over to disk brake one as they are different
    Jul 2010
    sydney
    yeah might have to just put it in,don't want it to wind and stuff though lol oh well i'll see how i go
    VL 5L
    Jan 2011
    cairns
    get a long screw driver and put metal end on the diff and plastic end to ur ear.....get someone to turn the diff u will be able to hear whats going on inside of it that way
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    look in my sig man on "MY RIDE" i have done the conversion. easy as. all straight forward.. this was drum rear end and i used all VN parts.. Callipers, Flex Hoses,Backing plates, etc
    VL 308 calais wagon, VR Ute
    Mar 2011
    Boyanup
    Gday, i have also just done a similar swap, changed a drum setup to a disc, you will also need the handbrake cable that goes with the disc brake setup, the drum brake cable ends are similar, but wont mount up and one will be longer than the other.
    VL Wagon, VSII
    Nov 2008
    Bolt on fit. Best brake mod I did on mine. The difference on mine was incredible.
    Couple of things you need to do tho.
    First, buy a couple of caliper overhaul kits from repco or where ever you want to get that type of stuff and service the calipers (including the slides) You don't know what condition those calipers are in. One of mine happened to be siezed.
    Second, you'll need to source a VN/VP 15/16ths brake master cylinder from a wrecker (and also run an overhaul kit through that too - change all the seals) as that will remove the drum preasure valve that'll be in your stock setup.
    Wouldn't worry too much about the handbrake cable as that can be made to fit and function so long as you just want it for parking!
    Cheers,
    Adam.
LinkBacks (?)
  1. 12-04-2011, 11:06 AM
  1. VR IRS diff question
    By stockyvrcalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-05-2009, 06:23 PM
  2. another diff question
    By rob drag racer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2009, 02:13 PM
  3. a diff question
    By POVRTY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2009, 05:17 AM
  4. question about diff gears in a irs diff vs 5.0l
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2008, 04:21 PM
  5. Diff question
    By joshsvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 10:50 PM
