hey guys,
got a problem with my reverse light... the one on the left doesnt work, the one on the right flickers.... :b: badly!! has anyone experienced something like this? is it a switch or sensor or poor earth line any help would be great
thanks guys
first of all what model commo you got, if it is a vl like mine i dont have reverse lights they packed up and now they wont work at allso i now have them hooked up to a switch
I got a 87 model, executive, manual if that helps too, the switch is a good idea though
You just may need some new wiring/soldering to the reversing lights.
Thanks guys, ill have a look when i get home from work and let you know how i go with it, battery drain is another big problem for me too but i think its more related to the cells in the battery then anything else
get the bat tested to see if its shagged.
reverse lights are most likely in the terminals. assuming you have checked the globes and one isnt blown.
i doubt its the switch in the selector or else nothing would happen in the lights at all. clean up the terminals for the globes, maybe replace the globes anyway and check the earthing for the lights at the back. very common problem. no need to wire a new manual switch when it could be a matter of repairing a loose wire.
Originally Posted by SNY.3LT
Is there a light in the boot?
Maybe it is always on?
nope, no light in the boot but i smacked one light (P/S/R -- which will need replacing) and tightned up the negative.... this seems to of fixed it but ill wait till later tonight to test it properly.... it mainly flickers when accelerating in reverse but it doesnt do it when its stainding still!
To me that defenitely sounds like a loose connection then if it mostly happens while moving.
Mine has that problem occassionally and what I have to do is tighten the part that holds the globe by turning it and then the light stays on
i had probs with my boot loom, it was the cause of, When i put my foot on the brake pedal the parkers at the front would come on.
do u took all the tape off n saw that one of the wires had been cut/stripped as a result of rubbing against something i guess... so i soldered her up n its working perfect!
...aS thE fOruM JunKie StRikEs aGaiN!...
thanks guys.. i think ive solved the problem by tightening her up, as i was reversing it in tonight it flickered once and stayed on its only really a problem for rego but it would be nice to have everything perfect!!
ive had probs wit my vl brake reverse and even indercators at first i thort it was the wireing looms but no, wat ya do is test them first wit a test light and if the light goes on its fine, afta that ya get a long nose pair of pliers and where the bottom of the globe sits in pull it out the metal bar things more then wat it is so its touching the metal bars propley and hey presto it should work perfict this also works on anycar wit the same prob unless the globe is the thing thats playing up or blown.
run new earth to body from taillights commodores always have bad earths there
cheers guys!I replaced a couple of fuses too, I had a problem with my high beams having to be held on. I originally thought it was the clockspring but after a look at the fuse box under the hood I was pretty shocked the Highbeam fuse had welded itself to the Fuse rail, everything around it had melt down.... next job..... replace that rail!
