Results 1 to 2 of 2
Thread: Hey fellas Small one i guess. got me stumped though
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Default Hey fellas Small one i guess. got me stumped though
    Hey boys
    Ok after i did a major service on the gearbox. as in pulled it out and put it on the bench did the input
    and output shaft seals, tighten bands, Changed filter, New fluid . also did the rear main on the donk,
    (main reason why i did the gearbox as well)
    Centre bearing etc etc u get me. after all put back in the car. i guess my problem is not connected. but i
    have vacuum in my crankcase now(Never noticed it b4 and this is something u cant miss). only started
    after i changed the rear main. (possibly sucking air in around my seal so i had no vacuum?)
    I pulled out my PCV valve (Positive i know not vacuum) and all was working fine,, so when i shut the car off
    if i pull my dipstick out i get a mad sucking sound till it equalises pressure... It is vacuum
    Car running if i plug the dipstick hole with my finger i get the vacuum again and then let off i get a big
    hiss again. is this of any concern i should have vacuum to some extent as this is how blowby is
    extracted from the crankcase. but like i said very noticible.
    Cheers Blokes
    Fellow JC member
    Nath
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    do you still have the pcv air entry hose to the inlet pipe off the rocker cover as well as the actual pcv valve hose into the inlet manifold from rocker cover
  1. Hi Fellas!
    By BadJesse in forum General
    Last Post: 08-01-2011, 02:41 PM
  2. im stumped so very very stumped rac 4 mechanics a dyognostic and a dyno still nothing
    By smokey_dj in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2006, 11:02 PM
  3. NT Fellas
    By Baritji in forum The Pub
    Last Post: 07-04-2006, 10:08 AM
  4. hey fellas
    By s0sage in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-07-2005, 12:54 PM
