Hey guys i need to get another set of injectors and rail because it could be whats causing my car to play up, just wondering though ive seen turbo fuel rails for $80 and i can get some turbo injectors aswell so im wondering if there bolt on to the n/a engine or theres different mods that need to be done?
Don't hold me on this but you need the turbo ECU as well for the injectors to work I think?
|8|7|R|B|3|0|V|L|
You can fit VLT injectors into a N/A rail there's no difference between both rails.
You can run vlt injectors in a n/a on a standard ecu but they will run rich. (not a bad thing) But if you want to boost them past 7psi then you need a vlt ecu
Modifying a car is like a drug once you start you cannot stop
Holdens if your not in one your behind one
Dont bother with vl turbo injectors on a n/a it will run like a pig and chew the fuel
