Results 1 to 8 of 8
Thread: will vp rear disc fit vl rear drum
    kowan's Avatar
    kowan is offline Clayton's Commodore
    91 Clayton's Commodore/Toyota Lexcen
    Sep 2005
    Far North QLD
    Default will vp rear disc fit vl rear drum
    can anyone tell me if vp rear disc will fit vl rear and if possible what is involved in the conversion? changing whole diff or can i just change the drum section to disc thanks for the help if anyone can
    http://aussiewholesalers.com now closed When I growup I`m gunna buy a real car
    86 vl commo
    Apr 2005
    brisbane
    hey hows it going the vp diff would fit in the vl but because the vp has a wider base you would only be able to have 16inch mags on the car.
    VL RB30 Berlina
    Nov 2003
    you and change the drums to disc but you have to change the wheel bearings and backing plates.....as for vp discs i'm not entirly sure whether or not they will fit.....i suppose that they can since vl turbo are the same as vn v8 discs....
    kowan's Avatar
    Sep 2005
    Far North QLD
    I took the whole diff from a VN Wagon (which already has the disc brakes) and put put it on my VL sedan....The only problem I had was that the rear shockies bottom bolts were to small so I drilled the rubber centre to fit the bolt. Also I had to tie the loose handbrake cable up a bit that was hanging down. Apart from those two things, it was too easy to do. "Life is so sweet now"
    POVRTY's Avatar
    POVRTY is offline building 5L VB TH 400
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    if you just whant the brakes then just swap the brakes if you want the diff ratio or a lsd out of a vp then swap the whole thing it all bolts up ok
    VS Commodore Omega
    Apr 2005
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Arrow brakes
    Quote Originally Posted by POVRTY
    Don't you have to change the master cly too or remove the non return valve for the rear brakes as drum brakes need about 8psi all the time and disks don't they will lock up...
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    POVRTY's Avatar
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    i put a later model lsd in a vb stroker and didnt change a thing. it all seemed to work ok. i dont knowabout the 8 psi but its defenatly worth doing some research
  1. VK diff drum to disc?
    By KiwiKommy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-03-2007, 12:04 AM
  2. disc rear end
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-01-2007, 10:04 PM
  3. Rear wheel bearing seals (width) drum V disk
    By digisol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2005, 11:42 PM
  4. drum and disc axal
    By craigvl038 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-09-2005, 07:15 PM
