Results 1 to 5 of 5
Thread: VL Problem! Won't start..
    RobboVl's Avatar
    RobboVl is offline VL REPPIN'
    VL commodore
    Apr 2011
    Exclamation VL Problem! Won't start..
    (Has been fixed)
    What's up guys!
    Yesterday arvo i decidied to give my VL engine abit of a degrease. I only had about 1/4 left of the can left, so it was not very much of a clean, Probably around 10 secs of full spray.
    Anyway i was being carefull were i sprayed the degrease and water, it was not getting on any cords or near the fuse box or anything important. Just the top of the engine near the holden logo.
    Anyway after i had hosed it all down and let it dry off abit i tried to start it, It started fine but it was running a tad rough, I could feel vibrations in the steering wheel ect.. So i drove it up to were i park it. (which is about 5 meters away) and then poped the bonet, I could see the whole engine was rough because it was moving around alot. I let it run for about a minute, Then it turned itself of. I started it again and it was running rough still, so i turned it off and let it dry in the sun for about 2 hours.
    When i came back after the 2 hours i tried to start her, And it wouldnt start, you can hear the fuel pump sucking in fine, it clicks through as its going to start but it just doesn't.
    I have checked all the fuses and the spark plugs and there fine and free of moisture.
    What can i do?
    Lowerd O.G Cruiser
    RobboVl's Avatar
    VL commodore
    Apr 2011
    87RB30VL's Avatar
    87RB30VL is online now Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    Lol what was the problem? Anything? That's a wierd one lol
    |8|7|R|B|3|0|V|L|
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    its water getting in the dizzy and over the Crank angle sensor.. As u stated once dried out boompa...
    Put a plastic bag over it next time man. it would be that the rubber seal for the cup and the crank angle sensor plug are brittle and not sealing properly.
    RobboVl's Avatar
    VL commodore
    Apr 2011
    Quote Originally Posted by 87RB30VL View Post
    The dude below got it spot on,
    a tiny bit of moisture in the dizzy.
    Quote Originally Posted by detox_nath83 View Post
    Yep, Thanks man.
    Next time i will put a bag over it. Cheers!
    Lowerd O.G Cruiser
  1. Start-up problem
    By PorkoWog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2010, 12:02 AM
  2. start up problem with gas
    By Fizzman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-10-2009, 06:11 PM
  3. start up problem
    By bboystyles in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2008, 07:56 PM
  4. Lpg start problem
    By fullymetal in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2007, 12:32 PM
  5. vr.start problem
    By deckadi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-01-2007, 09:30 PM
Tags for this Thread
