Results 1 to 2 of 2
Thread: vlt lsd centre and 28 spline axles into na diff housing
    VL Series 200 , 85 VK Berlina, VL Executive Wagon
    Apr 2010
    Default vlt lsd centre and 28 spline axles into na diff housing
    I have just bought a damaged vl turbo lsd diff where the plate with the four bolts on the end of the diff is slightly bent.. I've called and talked to a couple of shops and they either say it's stuffed or won't give me a proper quote to straighten it.
    So im thinking of just getting a na drum diff, pull everything of it and pull out the gears and replace them with the vlt lsd gears and put in the 28 spline axles with new bearings and seals. I would probably get a shop to do it so the backlash is set right and its all done properly.
    Is there any differences with the vlt and non turbo diff housings or are the axles and centre the only difference? And i was wondering how much i would be up for to have a vlt diff centre and axles fitted to a na diff with new seals and bearings pressed in?
    Apr 2010
    PLEASE DELETE. sorry double post..
  1. [QLD] Vlt lsd centre and 28spline axles into na diff housing
    By 88-SERIES200 in forum General
    Last Post: 17-04-2011, 12:01 PM
  2. 25 Spline diff gears into a 28 spline diff housing
    By kent3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2011, 08:58 PM
  3. [SA] Wtb: Standard VN / VP open wheeler diff centre (with shims and spline)
    By social in forum Swap / Wanted to Buy / Trade
    Last Post: 31-10-2010, 11:02 AM
  4. VS axles into VN Housing LSD centre ?
    By digisol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2008, 07:13 AM
