Results 1 to 8 of 8
Thread: does a strut brace help a VL?
    Pistol Guest
    Exclamation does a strut brace help a VL?
    just seen a pic of this calais turb and it had a strut brace over the engine, i thought these were only beneficial to front wheel drives.... do they actually help at all??
    VT
    Apr 2005
    QLD
    yeah, they do help. the later model commodores have a drop in firewall which are glued and are bolted in at the sides. this reduces front end rigidity between the strut towers. adding a strut brace increases the stiffness between the towers and aids handling etc.
    Pistol Guest
    cool so its worth gettn one but d'ya kno where? dont doubt new ones are easy to get, but how much? are wreckers likely to have one?
    jetspin_vn's Avatar
    jetspin_vn is offline JetSpin Racing Team
    VN GTS
    Nov 2003
    Mission Bay, Auckland, New Zealand
    Don't get a wrecked one, get a nice shiny new one. Nolothane or Whiteline. Around $220 - $280.
    JetSpin Racing Team Mantre:
    "F**k safety, I'm in a hurry"
    SNY.3LT Guest
    Are Strut Braces made out of Solid Steel/Other material, or Hallowed out Tubing of Steel/Other material?!
    VT
    Apr 2005
    QLD
    There are different types between the different manufacturers. the nolathane item for a vt is solid whereas the whiteline is tube....dont be concerned about strength differences between solid and hollow either...in most cases, tube or box section is exceptionally stronger than solid.
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    i got a nolathane one for about 170. its hollow alloy. its just to stop the shocks moving and collapsing into the sides of the towers. i saw a lowered one without it and the shocks had moved so much they were about to start tearing the towers or bend the shocks. definately worthwhile getting a brace
    Hector martinez Guest
    yeah they stiffen up and help in handling and aren't that much
  1. strut brace
    By vz 914 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-09-2008, 07:25 AM
  2. Strut Brace ....
    By sobvngrpa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2006, 11:07 PM
  3. GMH Strut Brace
    By vxcalais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2006, 09:13 PM
  4. strut brace
    By tgolds1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-08-2005, 11:24 AM
  5. Strut Brace
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2005, 12:54 AM
