Results 1 to 5 of 5
Thread: VL battery light on
    vl commodore executive wagon
    Jun 2010
    Default VL battery light on
    Hi guys I have a problem with me VL, couple of days ago the battery light come on so I figured the alternator wasnt working, so pulled it out and pulled the regulator of the back and the brushes were buggered, got them replaced by an auto elec and put it back together but still the battery light is on I have checked the fuses in the fuse box and all are fine. Has anyone got any ideas what it could be??
    Any help would be great thanks Chris
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    Wierd, my battery light was on so I replaced the alternator with a brand spanking new Bosch one and my light hasn't been on since
    |8|7|R|B|3|0|V|L|
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    exactly what it is...... Alternator
    run your car and get a multimeter on the battery posts a working alternator will show 14.2 volts... then drop when u turn your car of ultimately.
    Brushes have been changed as u stated but could be your diodes as well
    if its say 11.8 - 13V your alternator is Kaput
    Road trawling paddock bomb = moody VL
    Jul 2009
    goldfields VIC
    if your brushes were worn to shit the odds are you slip rings would be pretty worn as well...if they're not too bad then 30 seconds on a lathe and ya done. if they're dead then its just 2 solders to undo, a hammer and chisel to delicately remove the slip rings, and a hammer and socket to put the new slip rings on and then yeah just the 2 wires to re-solder.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    as above, it would have been cheaper replacing your alternator. with new or changeover.
    Nobody wants to play with me
  1. Please Help..Battery warning light and ABS light
    By martyrfc in forum Electrical Wiring / Questions
    Last Post: 30-04-2011, 03:03 PM
  2. Replies: 3
    Last Post: 26-05-2010, 09:22 PM
  3. battery light with brand new battery
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2010, 09:48 AM
  4. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  5. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
