Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By db_notso
Thread: VL - Screwed into fuel lines???
    Vs Exec
    Dec 2009
    Geelong, Vic
    Smile VL - Screwed into fuel lines???
    Hi everyone. Today i was mounting my sub n amp in my vl and as i was screwing a screw on the floor of the boot just above the fuel tank, i heard a sound of like air leaking out from underneath the screw. I undid the two rear bolts on the fuel tanks backets and dropped one side and had a look but i cant find any noticable holes in the lines going to the fuel tank. The car still starts and drives ok but hesitates to rev in neutral. What hose could of leaked air for a few seconds? no fuel is leaking...
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    vacum return? youll have to drop the tank down far enough to check the top of the tank and ALL hoses near the top AND FRONT
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    Screw the screw back in and pretend nothing happened lol
    |8|7|R|B|3|0|V|L|
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    IMCRZY's Avatar
    IMCRZY is offline RESPECT!
    M6 Hazzard SV6
    Mar 2007
    Wollongong
    You no doubt punctured the tank and the air u heard was probably the release of pressure from within the tank....
    Dont think there would be any vac lines near the tank lol, just a supply, return & vent
    I WISH MY GRASS WAS EMO SO IT WOULD CUT ITSELF
    Vs Exec
    Dec 2009
    Geelong, Vic
    Thanks for the reply's, If i have punctured the tank should i replace it straight away or is it ok? what should i do about the 'vacuum return' line?
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    there are 3 fuel vapour lines on the top of the tank towards the centre it could have been one of them, if it was the tank you should repair or replace it because the fuel system is pressurised or by the sounds of your description WAS pressurised.
    Nobody wants to play with me
    VZ SS
    Jan 2011
    Down under
    if you screwed into the boot floor it is hard to miss the fuel tank. likely you have hit the tank itself. Any pics of what you have done?
    vl berlina wagon 6cyl
    Jul 2005
    the vapor lines are usually broken and rotted due to use of cheap nasty plastic, so I wonder about pressure in tank
    its quite a job getting the tank out
  1. My Vy ute fuel sensor may be screwed
    By Afrikano in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-10-2010, 06:00 PM
  2. fuel lines and reg
    By CM99VT in forum V8 Development and Modification
    Last Post: 29-11-2009, 02:35 PM
  3. VP V6 Fuel Lines
    By bobgen111 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2009, 10:52 AM
  4. Vk V8 fuel lines
    By Drewsta in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-07-2009, 10:43 AM
  5. fuel lines
    By nemesis_adrasteia in forum General
    Last Post: 01-07-2009, 01:01 AM
Tags for this Thread
