hey guys i have just bought a diff from the wreckers and im just bout to rip the old one out and put the new one in is there anything i have to look for that would need replacing or anything like that if there is could i plzz get the names of the parts or bushes that would be needed
whats wrong with the old diff?
stuffed?
yea man it was a homejob lock diff and now the weld has cum apart and it is ****ed
just make sure you clean out all of the bits of old teeth and id say check the ends of the axles where they go into the diff for what kinda condition theyre in
check you're trailing arm bushes, sway bar and panard rod bushes.....if they haven't been replaced chance are they're stuffed!!!!
Click the scales.....you know you want to!!!!
