Results 1 to 18 of 18
Thread: spark issue with VL berlina
    VL berlina - Daily / VS Berlina - Project car :)
    Aug 2010
    Craimore, SA
    Default spark issue with VL berlina
    Hi ppl, just bought a VL berlina and it seems to have a spark issue..it will crank but the dizzi get nothing at all...i have replaced the dizzi with a brand new one, got brand new leads put on and still nuthing
    does any1 know what it could be????
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    coil?? transistor near the coil?? blown fuse?
    is the dizzy BRAND NEW or just new to your car?
    Nobody wants to play with me
    Aug 2010
    Craimore, SA
    yea the dizzy is brand new, and i havent looked at the coil yet...ill sus that out tomoro, thanks man
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    is that only the dizzy being new.. what about the Crank Angle sensor inside the dizzy.. is this new as well.
    if it is check the CAS plug ontop of the dizzy.. under the rubber boot that the wires are crimped on and not corroded.
    usually the CAS is your centre of problems about spark,,, then coil and so forth as Jatsvl has stated
    let us know man
    vl berlina auto soon to be 5sp man
    Apr 2011
    mid north coast
    agreed with detox one of my best mates had the same problem and it turned out to be the crank angle sensor
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    also check if the led;s on the ecu are flashing with the ignition on, could be a faulty ecu (very unlikely unless there is rust around the front windscreen and it leaks water onto the ecu)
    99% of the time it will be CAS causing the problem, its just process of elimination really. Have you got fuel? Can you hear the fuel pump prime when you turn the key on? (If you can, then most likely its not the ecu)
    Aug 2010
    Craimore, SA
    ok people thanks for the tips, i've done all that...but it seems theres no spark going to the dizzi from the lil black thing at the front of the motor????
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Aug 2010
    Craimore, SA
    the coil i think ???
    the black thing near the thermostat lol
    I dunno im not used to RB30's atm, more of a V6 bloke soz
    VL Calais V8
    Apr 2011
    victoria
    Ye
    CAS...
    Coil......
    The CAS plug is the culprit. always coroded, 80 bux cost me
    Aug 2010
    Craimore, SA
    wtf it started today and i had it running for a few minites and then it just died again outa no were and im back to were i stared >
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    a crank angle sensor will start the car on cold but once warm it will cough splut and/or just die. and so will the coil.
    the black thingy is the coil and the thermostat is in the side of the block on the bottom hose on an RB30 not the top hose like most.
    Aug 2010
    Craimore, SA
    oh yea now i get ya, but im sik of this crap...grrr
    i got 4 coils and replaced em all and still nothing...it just cranks and gets no spark to the dizzy, meaning no start
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    how u determining your getting no spark to the dizzy?
    have u backed out a plug and earthed it and cranked her over to c if ur getting spark?
    if not then i would suggest CAS. or something to do with the ECU
    have u run a diagnostic on the ECU. Check in the how to thread in my Sig below on how to pull the codes.
    have u checked under the rubber boot on the Coil Plug the 2 pin "T" plug thats on it for corroded/disconnected wires.
    this tells the coil when to switch over from the Power transistor signal wire...
    Highly unlikely to be a power transistor problem but possible.
    Check back man let us know
  15. #15
    Aug 2010
    Craimore, SA
    ok man cool, thanks
    Yea i've done the lead cheak and i got nothing
    Ill have a look in your thread
  16. #16
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    sorry man u never stated if the CAS was replaced with the dizzy or swapped over.??
    if not
    99% sure its your CAS.. very common problem with the rb30
  17. #17
    Aug 2010
    Craimore, SA
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    it appears everyone is leaning towards the crank angle sensor (CAS) on this one.
    there is a gold looking plate in the dizzy which is covering your CAS, undo the 2 screws remove the plate and there is a silver disc with lots of holes around the outside, on one side there is a black box type thing that the disc runs through, that is your CAS.
    if there is an amount of redish type dust under your gold plate it is a good indication your CAS is stuffed.
  1. VN is doing my head IN!!! Spark Issue
    By 1uz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-04-2010, 06:14 PM
  2. vx2 berlina 3.8 ecowreck on gas ....spark plugs??
    By richyrich in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-03-2010, 06:18 AM
  3. VT Berlina speaker issue
    By KnobbyBoi in forum ASR Audio & Electronics
    Last Post: 28-02-2010, 08:57 AM
  4. Help! Spark plugs for Berlina 2L 4Cyl ?
    By pony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-01-2007, 04:18 PM
  5. VN Berlina start issue
    By Bongo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-05-2005, 01:42 PM
