Results 1 to 7 of 7
Thread: RB30 PCV valve thread
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    Default RB30 PCV valve thread
    Hey all,
    Have put a catch can on my rb30, it is vented (track car, so doesnt matter).
    I have removed the PCV valve from the plenum but trying to track down the thread size of this valve, I am after a barbed fitting to screw into it's place (either 6mm, 3mm or 1/4 barb) for my boost gauge.
    Other then that there is a barb on the back of the plenum which connects to a metal line for the automatic transmission, anyone know the diameter of this? looks to be 6-8mm, so would need a T piece 6mm to 6mm to 3mm, anyone know if such a beast exists?
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    if its turbo leave the PCV valve or u will pressurize your crankcase and cause all dramas as it is a 1 way valve and closes with pressure in your plenum.. as for your other question, get a Vernier or take it to pirtek/enzed and get them to measure it. or take your pcv valve in and get them to match the thread size/pitch to it as a barb.
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    Why do i need to leave the pcv valve if running both breathers to a catch can? not sure i get it
    Catch can does have a breather filter on it, venting to atmosphere...
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    No worries will try pirtek
  1. Modifying standard RB30 to RB30 block / RB25 head + turbo... HELP!
    By 86VLred in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-09-2010, 12:07 AM
  2. Buick valve springs, valve train. need advice
    By GTP 85 in forum V6 Development And Modification
    Last Post: 25-08-2009, 10:22 PM
  3. skyline r31 rb30 coil on vl rb30 motor
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-04-2009, 10:30 PM
  4. Valve guides or valve stem rubbers?
    By Drewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-09-2007, 12:05 PM
  5. LT1 valve springs and crane valve locks
    By lxhatch in forum Parts And Other Items For Sale
    Last Post: 30-03-2007, 06:50 PM
