Results 1 to 6 of 6
Thread: VL running lumpy
    VL SL Commodore
    Jun 2011
    Default VL engine hezitation
    Hey guys.
    I recently bought myself a VL SL commodore n/a RB30 with the 5 speed. She was just sitting in some old ladies garage with 98,000km on the clock.
    Now, there are a few little niggles that its got.
    - There is a buzzing noise coming from the fuel pump (external) when i start up. Is this normal?
    - At about 60km/h there is a really high pitched squeal coming from the same general area. What do you think it is?
    - It runs fine when idling and when i slowly bring the revs up in neutral it still runs fine, but when accelerating it feels and sounds like its running on 5 cylinders. I replaced the fuel filter and put in some injector cleaner and it ran perfectly for one day but then went back to its nasty habits. What could this be? Im thinking maybe it has something to do with the fuel pump, maybe the afm, maybe dirty crappy fuel left in the tank? But i honestly dont know.
    Please help!
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    firstly welcome to JC forum.
    the fuel pump should buzz for about 7 secs when you turn the key ready to start, then after you start it will buzz continuously, if it is unusually loud there maybe a problem with it or fuel regulator.
    the squeal is probably a wheel bearing, faulty rear brake part or more commonly centre bearing in the tailshaft.
    what fuel do you use?
    Nobody wants to play with me
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    I've found out that my fuel pump is good to me if I turn the ignition on until the buzzing stops, start her up, and keep her above 1/4 tank. When the tank gets low, the fuel pump whines like a bitch cos', well, there's hardly any fuel in the tank which makes the pump work harder. As for the high pitched squeal, I wouldn't know any useful ideas on that one, sorry. Also, welcome!
    |8|7|R|B|3|0|V|L|
    VL SL Commodore
    Jun 2011
    im running her on premium.
    the other day i replace the fuel filter. i also took out the external fuel pump and just put it back in just to check it out (probably doesnt make a difference). The day after that, she ran perfectly. that was the only time its actually worked. then the day after, it started running rough again. im fairly sure its something to do with one of the fuel pumps. how would i diagnose any problems with either pump?
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    could be a failing pump.... but a AFM thats on its way out can also cause this..... or it being out of spec and needs a tune
    other factors could b CAS, crappy leads/plugs/ worn dizzy cup and rotor, dirty intake/throttle body
    bad fuel
    timing etc etc
    goes on and on
    go over all electrical plugs in your engine bay with contact cleaner or INOX/WD40
    welcome to JC and goodluck let us know.
    VL SL Commodore
    Jun 2011
    thanks mate. ill do that and let you know how i go.
  1. Lumpy cam for a 96 vs v6??
    By sammyboyy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-08-2010, 09:16 PM
  2. VT 5L Lumpy Cam help
    By MattyC in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-07-2010, 09:42 PM
  3. Lumpy Cam
    By vpdrifta69 in forum General
    Last Post: 24-04-2010, 05:10 PM
  4. lumpy cam
    By tionaboy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2010, 09:24 PM
  5. getting lumpy
    By blaze in forum V8 Development and Modification
    Last Post: 22-11-2009, 09:25 PM
Tags for this Thread
